Passenger door won't lock? - Pontiac GTO Forum
post #1 of 5 (permalink) Old 09-04-2013, 08:35 PM Thread Starter
So my passenger door won't lock anymore.
If I hit the button in center or the lock button, you can hear the motor working for both doors but the lock thing doesn't move on passenger side.
It's actually stuck down, in "lock mode" but it's not locking.
My alarm works as I noticed.
5mgelt1ls2 is offline
post #2 of 5 (permalink) Old 09-05-2013, 05:36 PM
68OldGoat's Avatar
You might want to remove the passenger door panel and check the linkage. Doesn't sound like an electrical issue from your description.
68OldGoat is offline
post #3 of 5 (permalink) Old 09-05-2013, 10:42 PM
jpalamar's Avatar
Probally the door lock actuator. I've read about a few others failing as well.
04 GTO - sold
jpalamar is offline
post #4 of 5 (permalink) Old 09-07-2013, 09:58 AM
skurfan's Avatar
The door lock actuator would be the most likely, but if you live and park under trees that produce sap like a hedge tree it could be as simple as sap buildup from years of up and Down. That's a cheap easy fix and worth a try.
skurfan is offline
post #5 of 5 (permalink) Old 09-19-2013, 07:35 AM
SANDU002's Avatar
Sounds like door lock actuator to me. Common problem on Pontiacs. I had this same problem with my G6.
67 Post Coupe,
69 RA III Judge
06 BOM, M6, 18's
SANDU002 is offline
passenger door won't open from outside woolsey10 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 3 04-16-2012 11:35 PM
Passenger Side Door Lock awsumvet Interior Discussions 1 12-05-2007 03:24 PM
Passenger Door Lock Acuator djdonte 2004-2006 GTO General Discussion 1 09-24-2007 05:08 AM
'04 GTO - passenger door lock nsr Service, Maintenance and Technical Discussion 3 07-26-2007 09:54 PM
Passenger Door lock question kevracer Interior Discussions 5 10-20-2006 06:33 PM
