Those of you who've installed it, where in the car did you put the unit and the antenna? Trying to see if I have to run the lines all the way to the trunk or maybe there is a better option.
I mounted the antenna on the roof centered just above the back glass, used a credit card and pushed the wire under the weather strip and ran all the way up and came in the drivers door jam and in through the loom that goes to the door, the module will fit under the center console just behind the shifter, on a m6 idk about a auto car...The pioneer Bluetooth module is even larger, it was the pain to find a place for it
Thanks. It hopefully it makes it easier to install in front. Fortunately I don't have to deal with the BT module. You just tapped the yellow wire to the yellow on the harness?
I mounted mine on the trunk decklid just behind the CHMSL. I ran the cable from the XM Module (which is mounted in the trunk), up the gooseneck (ziptying it to the existing bundle, and then wrapping it back around under the felt on the trunk lid. The weather stripping of the trunk does let a tiny bit of water in if you directly spray that location, otherwise no leaks to speak of.
I can take a picture of my mounting location if you so need it.
the yellow wire is intended to be ran to the yellow wire in the radio harness, however any constant positive will work. it has to be a constant to keep the memory in the tuner.
I have the antenna in the same spot shown above. I probably should have put my tuner there, but I ran the antenna to the front along the passenger side and placed the tuner above the hush panel just below the blower motor.
I didn't put anything between the lid, I do have some scratches but nothing I'm overly worried about (my front end is a rock chip nightmare since mine is a DD). If you don't want scratches, then take the antenna off (throw it on the underside) before using an auto car wash. Other than that it really never moves (and thus never creates scratches).
You'll have to cut some "relief" into the felt that sticks on the gas tank if you mount the XM Module where I did (I basically cut two 1 inch cuts in it, never removing any material, just cuts). I tried to take a picture of that with my iPhone, but it came out fuzzy.
Does anyone that has this XM module ever get a "check antenna" error message? Mine randomly gives this message, has only done it a hand full of times, and usually i can just power off the radio and it will come back on working. anyone else seen this problem or do i just have a lemon?
If I start the car in a place with weak signal I don't get the fancy station icons on my preset list, but that's it (I have the Z130BT Software on my HU).
How is your antenna routed? The reason I put mine in the trunk is that is where most OE's put it as to make the antenna routing as short as possible.
Ran the cables for XM and the back up camera to the front. Now going to tap the XM and the back up camera into the tail harness. Just confirming my wires. Reverse camera positive into the light green and grounds for both into the black. Correct?
Brilliant. I had that messed up. What I had labelled as constant power was actually Pin 4/Backup Lamp PS on the female plug. Still looks like yellow under light. Also I didn't see the blue stripe on Pin 1 Ground.
Thanks again for the information and your patience.
Yup. Same here. Especially since the last time I swapped a radio it was on a '95 Villager and literally plug'n'play.
Now on to soldering the speaker wires of the radio harness and the brake bypass.
Related Threads
Pontiac GTO Forum
514K posts
38.4K members
Since 2004
