radio not working! :( - Pontiac GTO Forum
post #1 of 6 (permalink) Old 08-28-2011, 08:19 AM Thread Starter
just bought my goat and as I knew when i did the radio does not work. who ever traded it in had an Amp in the back and the wires are disconnected. In the trunk there are 2 ends of a green wire that are disconnected, My hope (cus wiring isn't my thing) is that all I have to do is reconnect the wire to one another to restore the connection and have music!
is it this easy? could it be?
omen omega is offline
post #2 of 6 (permalink) Old 08-28-2011, 10:40 AM
Bossin's Avatar
take it to a shop n just ask better if you connect the wrong wires u can blow something out
Bossin is offline
post #3 of 6 (permalink) Old 08-28-2011, 09:30 PM
post a picture of the wires. i might be able to help you out
dude515 is offline
post #4 of 6 (permalink) Old 08-29-2011, 01:22 AM Thread Starter
http://farm7.static.flickr.com/6207/...838cf760_m.jpg
or Flickr: robertlmeyers' Photostream
any help would be greatly appreciated. I rather not take it to the shop. There is also 2 prong red wire out of the cameras view.
post #5 of 6 (permalink) Old 08-29-2011, 05:58 PM Thread Starter
those are the trunk wires
post #6 of 6 (permalink) Old 08-29-2011, 07:27 PM
those are stock amp wires. i think i might know what happened because i sort of did the same thing. they put in an aftermarket amp by using the wires that feed full signal to the stock amp with a line out converter so they didnt have to replace the head unit. if you pull back the carpet on the driver side, there should be a little black amp behind a pannel. if the connector is still there, just splice colors back together and check all fuses. also if thats the route they took then they most likely pulled the head unit to get accessory voltage. there is a sticky on how to pull the head unit. follow that and check out the wiring harness to make sure its not mutilated and that its seated properly. since those wires were left bare its a possibility that they shorted and blew a fuse.
dude515 is offline
Gauges not working on '68 mrvandermey 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 06-20-2011 08:00 PM
tach not working right SIXT5GTO 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 05-23-2011 08:42 PM
AC compressor not working The intimidator Service, Maintenance and Technical Discussion 1 01-06-2011 03:55 AM
Attachments are now working, 05GTO Gtoforum.com Site Help 0 03-27-2006 08:54 PM
