Sagging roof liner= water leaks? - Pontiac GTO Forum
post #1 of 6 (permalink) Old 10-30-2011, 03:47 PM Thread Starter
I went to look at an '04 the other day and the roof liner is sagging quite badly. Does anyone know if this is a sign of a damp interior?
IRONSIGHT is offline
post #2 of 6 (permalink) Old 10-30-2011, 04:17 PM
Falco21's Avatar
No but a sign of a damp interior would be if it was wet. The headliner on these cars is known to sag. Mine is sagging bad right now.
This is a perfect moment to upgrade the ****ty stock material to unisuede to match the door panels.
"If you want more inches.....STROKE IT!!"
Falco21 is offline
post #3 of 6 (permalink) Old 10-30-2011, 04:29 PM
chilliwhiggerE's Avatar
Location: Hollywood, Florida originally from Pittsburgh, Pa.
I have an 04 and just had my headliner re-upholstered. I had it done in a lighter sueded material as suggested above. It cost me $70 but I took it out myself and took it to the shop. It's easy and it's made out of styrofoam so it will take some bending. If you choose to do this I recommend being very careful with the velcro attachments by the rear window.
chilliwhiggerE is offline
post #4 of 6 (permalink) Old 10-30-2011, 06:57 PM
Do you know of where I could find a guide on getting it out?
Jeffcarr is offline
post #5 of 6 (permalink) Old 10-30-2011, 07:45 PM
Falco21's Avatar
How to: Remove headliner - LS1GTO.com Forums
Falco21 is offline
post #6 of 6 (permalink) Old 11-03-2011, 07:22 PM Thread Starter
I know it's a common problem on these cars along with water leaks so I thought the 2 might be related. I figured if the interior carpets were wet and not dried out quickly, the humidity inside the car might be higher than usual and cause the glue to separate. Thanks for all the info.
Cheers.
Water Leaks Into Trunk Strange Rubber Goop Help!!! NorwalkNugget 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 12 10-07-2011 09:19 AM
Headliner Sagging Falco21 Interior Discussions 11 04-02-2011 02:01 PM
Sagging 67 GTO HELP! gtodetroit 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 08-26-2010 09:47 AM
Sagging Springs ROBSGTO Drive train, suspension, alignment and brakes. 36 01-02-2009 12:16 PM
sagging ass Empaler 2004-2006 GTO General Discussion 6 01-20-2006 12:59 PM
