SCCS Gauge install - Pontiac GTO Forum
post #1 of 3 (permalink) Old 09-04-2012, 10:32 PM Thread Starter
SCCS Gauge install
Wiring SCCS (SpeedHut) boost and Fuel psi guages in SCCS pod, I have wiring instructions for use of Fuel Door harness, but want to wire using interior fuse panel. What fuse locations can I use an add a fuse to wire these gauges? I need +12v keyed ignition and another +12v source for gauge lighting and dimmer circuit for gauge face illumination. Has anyone installed SCCS gauges or other boost and Fuel psi gauges with illumination from the interior fuse panel? Thanks in advance for your thoughts.
SWGOAT is offline
post #2 of 3 (permalink) Old 09-06-2012, 12:24 PM
The connector under the radio has all of those and they are not being used unless you have the smoker's package in your car. You're welcome
post #3 of 3 (permalink) Old 09-06-2012, 09:33 PM Thread Starter
Thanks, I totally forgot about that plug. I do not have the smokers package and will wire the guages to that point. Should have good access from console guages to that plug. Good call, thanks again.
SWGOAT is offline
SCCS gauge install/05 SWGOAT 2004-2006 GTO General Discussion 0 06-05-2012 11:19 AM
Vacuum Gauge Install gtoearl 1964-1974 Tempest, Lemans & GTO General Discussion 20 06-13-2010 08:00 AM
JHP Gauge Pod Install Question lotaguts Interior Discussions 12 10-10-2009 05:10 PM
Team SCSS Gauge Install bluebluemblue Interior Discussions 7 01-23-2008 09:56 PM
Install Trans Temp Gauge on 05? macdogg Service, Maintenance and Technical Discussion 0 10-27-2005 09:51 AM
