Screen - Pontiac GTO Forum
post #1 of 14 (permalink) Old 04-09-2006, 10:09 AM Thread Starter
Screen
I was just wondering what all the little screen on the Center can show??
BlckGTO04 is offline
post #2 of 14 (permalink) Old 04-09-2006, 10:17 AM
In addition to the factor programmed stuff... this is available!
http://www.whiteautoandmedia.com/Con...ogramming.aspx
GTO Roper is offline
post #3 of 14 (permalink) Old 04-09-2006, 01:12 PM
Hold the Mode, and Set button at the same time while starting the Car. Then you can scroll through all kinds of stuff.
C5ORGTO is offline
post #4 of 14 (permalink) Old 04-09-2006, 07:49 PM
Mike_V's Avatar
Does anyone know if you can keep the speed displayed without the left and right screens going blank? I like the digital speedo, but I'd also like to see my MPG readout at the same time.
Mike_V is offline
post #5 of 14 (permalink) Old 04-09-2006, 10:00 PM
raven1124's Avatar
Send a message via Yahoo to raven1124
The way you do it is, in normal mode, put it on what you want, as far as what you want to see on the right and left screen. Then hold mode and set when you start her up and you should see the avg MPG or whatever is on the left and right that you had during normal mode. Also, when you do the hold and set thing, you can view you digital speed by just cycling through it until you see it. I hope this makes sense, Mike.
raven1124 is offline
post #6 of 14 (permalink) Old 04-10-2006, 02:24 AM
Mike_V's Avatar
Holy crap, it’s possible? Man, I’m going to try this first thing in the morning. Thanks Raven.
Mike_V is offline
post #7 of 14 (permalink) Old 04-10-2006, 03:16 AM
raven1124's Avatar
No problem. Hope it's what you were talking about.
post #8 of 14 (permalink) Old 04-10-2006, 03:20 AM
hmm well i tried, but no dice. Here's what i did
i set it to have the instant and overspeed by just turning the key forward. Then i held in set and mode, and started the car. I then hit mode to cylce threw but it cycled everything. What am i doing wrong??
i want overspeed and instant displayed with the speedo
jagyro is offline
post #9 of 14 (permalink) Old 04-10-2006, 03:44 AM
raven1124's Avatar
I'm going to check on it now.
post #10 of 14 (permalink) Old 04-10-2006, 03:50 AM
raven1124's Avatar
Ok it worked for me. Let me see if I can explain it better. Turn turn your key to on (in normal mode) and put it on where instant and overspeed is on the left and right screen ( it will work on any of the left and right screen features). After you do this, turn your car to off and take out your key. Now put you keyback in and hold set and mode and turn your car to on or start it up and the instant and overspeed should be on the right and left screen. Let me know if it works or doesn't.
