Speedometer problems - Pontiac GTO Forum
post #1 of 5 (permalink) Old 10-28-2013, 09:07 AM Thread Starter
I have a 69 GTO and the last several cold (40 to 50 degrees) days I took the car out the Speedometer made a scraping like noise and the needle was bouncing around like crazy. It would go from 40 to 120 mph and back and forth. AFter stopping for breakfast the car sat in the sun and when I started it and drove on to the road the Speedo seem to work fine except for an occasional back and forth jumping. The scrapping noise also stopped or at least diminished quite a bit. I figure it is in the cable, maybe needs to be changed or lubricated. Could it also be in the speedo casing itself?. Any comments would be appreciated. thanks Soups.
Soups is offline
post #2 of 5 (permalink) Old 11-01-2013, 07:39 PM
mbergin's Avatar
Quoted: 8 Post(s)
I have the same problem in my 69. I changed the cable and it didn't help. It's not as bad as yours so I just live with it.
Sent from AutoGuide.com App
mbergin is offline
post #3 of 5 (permalink) Old 11-02-2013, 06:35 AM
Sure. It's not a difficult fix at all. The cable does need to be lubricated. Disconnect the cable at the transmission end then pull the center cable all the way out of the sheath. Get yourself some of this stuff:
Dorman Champ 9-1812 - Speedometer Cable Lubricant | O'Reilly Auto Parts
Lube the cable up good, slide it back in (twist it as you're pushing in the last few inches to make sure you re-engage the speedometer), reconnect and you should be in good shape.
post #4 of 5 (permalink) Old 11-04-2013, 06:24 AM Thread Starter
Thanks for the info. I will probably change the cable since I have no idea if it is the
original or not. They are not that expensive and pretty easy to install. I hope that is the problem. As you know if it is in the speedo head then that is a little more involved.
Soups
Soups is offline
post #5 of 5 (permalink) Old 11-04-2013, 07:58 PM
Of course you're free to do as you like, but in my experience the reproduction cables brand new are poor substitutes for even worn factory originals. If'n it were me, I'd at least try to lube the original. If the results aren't satisfactory then the other option is still there.
Speedometer Cable? xconcepts 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 08-13-2010 11:07 AM
speedometer Q8 GTO 2004-2006 GTO General Discussion 12 07-16-2009 10:08 PM
Speedometer mdilello 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 08-08-2007 09:54 AM
Speedometer off aryanramsey Drive train, suspension, alignment and brakes. 9 03-14-2007 12:21 AM
Speedometer was OFF! C5ORGTO Service, Maintenance and Technical Discussion 8 04-24-2006 03:55 PM
