Steering wheel volume button broke - Pontiac GTO Forum
post #1 of 8 (permalink) Old 10-21-2011, 07:44 PM Thread Starter
I discovered after I purchased my 05 GTO that the volume "up" button on the steering wheel seems broke. The plastic button itself was just flopping around and didn't seem attached. (Note: the actual button itself still works) I used a small screw driver and popped out the loose button and as far as I can tell it doesn't seem broken, but I'm not positive. Any thoughts?
I'm hesitant to take anything apart steering wheel related because of the air bag.
I'll try to get a picture to better illustrate the issue if needed. Thanks
cesjr02 is offline
post #2 of 8 (permalink) Old 10-31-2011, 12:59 PM
646904GTO's Avatar
I had the same issue when I bought my 04. I seem to remember that there is a little silicone button that makes it return to the up position after you push it. Anyway I bought a new assembly from Pontiac. The airbag is not an issue if you disconnect the battery. I failed to do that and then I accidentally pulled the airbag plug and it set an airbag code that only the tech2 scanner can erase so I had to take it to the dealer and it cost me a 1/2 hr of labor for the reset. So lesson learned, disconnect battery, unplug air bag, replace switches, plug in airbag, connect battery.
1969 400 T400 auto 2nd owner
1973 Challenger 360/727
1931 Ford Model A
646904GTO is offline
post #3 of 8 (permalink) Old 10-31-2011, 01:02 PM Thread Starter
Do you mind if I ask how much the dealer charged you for a new assembly? Will they sell you just the audio controls themselves?
cesjr02 is offline
post #4 of 8 (permalink) Old 11-17-2011, 01:02 PM
SleeperGoat's Avatar
the entire volume control buttons on the steering wheel are around $150 at the dealer. i went to gmpartsdirect and ordered them for $89 and around $22 for shipping and processing.
SleeperGoat is offline
post #5 of 8 (permalink) Old 11-17-2011, 01:41 PM Thread Starter
Nice, thanks! Question, the 06 radio controls light up, correct? They are the same price, will the 06 audio controls bolt right up to my 05?
cesjr02 is offline
post #6 of 8 (permalink) Old 11-17-2011, 04:17 PM
AlaGreyGoat's Avatar
The 06 illuminated buttons will work on an 05, but you will need an 06
clockspring.
Larry
AlaGreyGoat is online now
post #7 of 8 (permalink) Old 11-17-2011, 04:40 PM Thread Starter
Thanks for the info!
cesjr02 is offline
post #8 of 8 (permalink) Old 01-29-2012, 11:42 AM
Gtojustin's Avatar
You wouldn't happen to know the part number of the volume controls? Thanks
Gtojustin is offline
Wheel stud broke Weisberg16 Wheels and tires 4 09-12-2011 04:06 PM
steering wheel Lorrie Ann Interior Discussions 4 03-29-2006 03:18 PM
power steering line broke bluhaven Service, Maintenance and Technical Discussion 1 05-25-2005 05:50 PM
