stereo system - Pontiac GTO Forum
post #1 of 5 (permalink) Old 09-30-2008, 04:31 PM Thread Starter
stereo system
i have 2 twelve inch treo subs an a 1200 watt treo amp. I havnt decided if i want to hook these up or get rid of them and get new speakers/amp to replace the ones in it. Need opinons. Also if i do decide to keep them what is the easiest way to run wire into the trunk with least as possible showing.
sampsonite is offline
post #2 of 5 (permalink) Old 10-06-2008, 02:27 PM
teamgs's Avatar
Depends if you value booming bass over trunk space.
Personally, I value trunk space. You can put 8-10 inch subs in either the rear deck or rear quarters. You would build a couple of boxes for the rear quarters, but there is no room to build an enclosure in the rear deck. For the deck, you would simply get free-air or infinite baffle compatible woofers.
I put two 8" subs in the rear deck.
You can easily run wires to the trunk by removing the lower door sill cover, and the rear seat.
Regards,
Gary
1 of 97 - Quicksilver Metallic, black leather, factory 18"s, CAGS eliminator
teamgs is offline
post #3 of 5 (permalink) Old 10-06-2008, 03:14 PM
Regards,
Gary
exwrx is offline
post #4 of 5 (permalink) Old 11-06-2008, 03:35 PM
The Joker
Hi, im in search of a guy that hangs out here with the screen name THE JOKER..
Im told he's the one to see in ref. to fiberglassing a enclosure for the rear trunk of the GTO..
Michael
[email protected]
YAHOO: MB30126
MBGTO is offline
post #5 of 5 (permalink) Old 11-06-2008, 08:43 PM
well, just a quick update on my system, ive been working on. it's been awhile since my last post on this topic. Anyway, I am up to a Kenwood DDX-512 stereo, (4) 6 1/2 infinity, (2) 6 1/2 infinity component (set), Kicker 650 x4 (4channel) amp... and it sounds great! My final intallation will be (2) Kicker Solo Barics 12" w/custom box, 1500watt Kicker amp,and custom lighting in the trunk to match my cars color. I will post pics of the finished product...
htowngto04 is offline
Check Engine Code - Catalyst Sys Efficiency Threshold (bank 1 & Bank 2) cjsuttonx Intake and Exhaust Discussions 5 08-24-2008 07:42 PM
Remote Code Key & Theft Deterrent System GM4life Service, Maintenance and Technical Discussion 0 06-14-2008 11:13 PM
TSB Information for 06 GTO Red Bearded Goat 2004-2006 GTO General Discussion 4 06-02-2007 09:00 AM
Stock stereo system? benh818 2004-2006 GTO General Discussion 15 04-07-2005 07:11 AM
