Swapping seat bottoms? - Pontiac GTO Forum
post #1 of 5 (permalink) Old 08-22-2012, 10:42 AM Thread Starter
Giacobazzi's Avatar
Has anyone swapped the seat bottoms on the front seats? The passenger seat is so pristine and the drivers shows some wear, it would be nice to swap them!
Giaco
Giacobazzi is offline
post #2 of 5 (permalink) Old 08-23-2012, 09:01 PM
Take the seat out but don't unplug the airbag connection or you will need to go to a dealer and have them turn the airbag fault light off which they will prob charge you for. take the seat apart and remove the bottom upholstery, replace with new one and reverse process.
smitty2919 is offline
post #3 of 5 (permalink) Old 08-24-2012, 12:35 AM Thread Starter
Giacobazzi's Avatar
I didn't realize the seats had side airbags. So what you are saying is to just pull off the bottom leather cover and swap?
post #4 of 5 (permalink) Old 08-24-2012, 10:27 AM
jpalamar's Avatar
I don't see any reason why you couldn't... but don't know why you would.
04 GTO - sold
jpalamar is offline
post #5 of 5 (permalink) Old 10-03-2012, 09:19 AM
The seats don't have airbags, they have a harness that has to do with the airbags. I believe it attaches to the seat.
So in order to remove the seat you have to detatch the airbag harness from the seat but don't unplug it. Then you can remove the seat.
Passenger seat removal without Air Bag light - LS1GTO.com Forums
Swapping radios iwant2buyaGTO Interior Discussions 37 06-23-2010 08:35 PM
05-04 Swapping goatCurious Exterior Discussions 9 06-10-2010 03:22 PM
Swapping guages jpalamar Service, Maintenance and Technical Discussion 18 02-14-2010 08:23 PM
Swapping a 66 from the standard 335 to the Tripower? xconcepts 1964-1974 Tempest, Lemans & GTO General Discussion 11 01-12-2009 03:38 AM
Swapping out the 3sp for an M22 4spd jim's68 1964-1974 Tempest, Lemans & GTO General Discussion 1 06-16-2006 08:52 PM
