is there a way to remove the ignition switch without using the keys??? - Pontiac GTO Forum
post #1 of 6 (permalink) Old 05-06-2013, 06:52 AM Thread Starter
I have a 2005 gto and my ignition won't turn at all and I hope there's a way to remove it without the key in the on position. I also got my new switch with cylinder in today but the whole thing is disassembled springs and all! can someone please help?!
adrietucker is offline
post #2 of 6 (permalink) Old 05-07-2013, 11:20 PM
have you tried to rock you steering wheel back and forth while rotating the ignition?
mananswers is offline
post #3 of 6 (permalink) Old 05-08-2013, 10:06 AM
There's an updated housing that fixes this issue. you don't need to replace your ignition tumbler just the housing it goes into. I believe its about a $30.00 dollar part. Mine was doing the same thing last summer. There's some detailed installation instructions on here somewhere.
Hers the GM part number for the updated housing
92234035
mikes06goat is offline
post #4 of 6 (permalink) Old 05-09-2013, 10:46 AM
68OldGoat's Avatar
Try this location for the detailed write up with pics for your fix!
How to: Ignition Cylinder removal and disassembly w/ pics! - LS1GTO.com Forums
68OldGoat is offline
post #5 of 6 (permalink) Old 05-09-2013, 05:43 PM
A fix may work as well as getting the part. I had a friend that had 2 replaced by a dealer with the "improved" part.
post #6 of 6 (permalink) Old 05-12-2013, 03:48 PM
My new one was tight and wouldnt turn correct, so I fixed the old one. As far as getting the key to turn, shoot some canned air in upside down. Cooling everything seems to help.
ppxstnr is offline
67 Ignition switch lam63 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 06-13-2012 03:44 AM
new ignition switch BillGTO 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 10-26-2009 03:34 PM
remove ignition cylinder with no key????? crustysack 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 08-17-2009 06:23 AM
65 ignition switch asshauler 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 02-26-2009 12:58 AM
Ignition Switch? 66_goat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 10-29-2007 11:13 PM
