1967 GTO Convertible Doors Bad Fit - Pontiac GTO Forum
post #1 of 4 (permalink) Old 06-19-2019, 08:30 PM Thread Starter
So we now have the front fenders on the car and they are perfect. The door gap to the rockers are about perfect as well BUT the gaps at the fender and quarter are excessive. I have two sets of doors and all 4 doors measure the same.
Any thoughts here. The door opening is about 7/8" greater than the door measure.
matthewjend is offline
post #2 of 4 (permalink) Old 06-19-2019, 08:57 PM
Quoted: 332 Post(s)
Fit the door to the quarter panel/rocker first. Then fit the front fender to the door.
Keep in mind that these door gaps are not like todays cars. They have rather wide gaps to compensate for flexing as compared to our newer cars that are unit body and designed rather stiff.
post #3 of 4 (permalink) Old 06-21-2019, 12:21 PM
May be a tad late on this. Usually,you assemble back to front, as the only adjustments u have is door and fender. My 66 convertible I lined the door upwith the bottom of the A-pillar.. pontiac Jim is correct on the gaps on these cars, they didnít pass the ball bearing test from the factory. I had a slightly large gap but fixed that by installing the door edge protectors
Gtowally is offline
post #4 of 4 (permalink) Old 06-22-2019, 09:30 AM
Quoted: 20 Post(s)
also on the front fender to door gap the fender edge is 1/32 proud of the door edge according to Fisher Body, lets door slip under without binding at body lines. my car has never been taken apart and the doors shut with two fingers it is evident on both sides.Hate to scrape the paint.
Instg8ter is offline
  Pontiac GTO Forum > The 2004-2006 GTO > Exterior Discussions
