1157 LED bulbs for my '66 GTO - Pontiac GTO Forum
 6Likes
post #1 of 15 (permalink) Old 09-07-2018, 11:00 PM Thread Starter
Ok, Im going to try to not be too long winded. And if there's another thread already discussing this, please point me in that direction.
Ive converted all my 1157 bulbs in my 1966 GTO to the proper LED replacements. Even spent the $ and got the correct flasher for said LED bulbs. Now for my issue... The brake light, tail lights, rear turn signals work amazing. Very happy with that. The front is where my issue lies. The marker lights work fine but BOTH front turn signals flash at the same time, no matter which way I flip the arm. Everything worked fine with all the old bulbs. So, I know the wiring of the car is fine. Do I need to ground something? Do I need a different resistor somewhere to make the fronts work properly? Has anybody else done this and run into this issue? Im open to suggestions.
Thank you ~ Phil
Hudlow66 is offline
post #2 of 15 (permalink) Old 09-08-2018, 08:01 AM
Quoted: 126 Post(s)
Thank you ~ Phil
Sounds like you have a switch problem as you are energizing both circuits. Did it work properly before the LED conversion ?
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is offline
post #3 of 15 (permalink) Old 09-08-2018, 11:11 AM Thread Starter
Yup. Everything worked perfect before swapping bulbs. I messed around with it a little more last night. There is a small amount of current running through the opposite side of which your signaling. As in, with the right side signal on, the test light flashes on the left socket. With the left side signal on, the test light flashes on the right, as well. It's very faint on the test light but more than enough to fire off the LED. Ground issue? Not enough resistance?
Hudlow66 is offline
post #4 of 15 (permalink) Old 09-08-2018, 11:43 AM
Ricker's Avatar
I wish I had an answer for your crossed circuit problem, but I am curious about your choice of LEDs for the tail lights. I tried some out, but because the bulk of the LED modules are on the end of the "bulb" and our tail light bulbs stand vertically within the light capsules, mine ended up no brighter than the incandescent 1157s. In other words, most of the light brightness was directed straight up and not out through the tail light lenses. Did you find some LEDs that project out the side of the bulb, instead of the end?
Ricker is offline
post #5 of 15 (permalink) Old 09-09-2018, 05:11 AM
denrael's Avatar
Thank you ~ Phil
If the rear t/sigs work separately as designed, that pretty much eliminates any problem in the t/sig switch itself. Particularly given the fact you're getting some voltage to the "wrong" side, I'd bet nickels to nuclear warheads you've got a ground issue in the front end somewhere. It may have been there all along, with the heavier load of the 1157's possibly masking the problem.
Hudlow66 likes this.
denrael is offline
post #6 of 15 (permalink) Old 09-09-2018, 05:53 PM Thread Starter
Yeah, I found these bulbs and they have the diodes on the face and all around, as well. Not sure how to post a picture on here but they seem like a decent piece. Ill dive back into this when I get a little more time. A ground issue sounds (at this point) like the most plausible cause, to me. Ill keep checking back and if I find the issue, Ill post it. Might help someone else. Thank you, guys
Hudlow66 is offline
post #7 of 15 (permalink) Old 09-13-2018, 03:05 PM
Ricker:
Just a quick question: Are you trying RED LED bulbs in the back and not white? I learned this lesson. Something about which color light that the lenses are meant to pass. Sounded weird to me but it turned out to be true. Mine is a 67.
chemnick is offline
post #8 of 15 (permalink) Old 09-13-2018, 03:08 PM
Hudlow66:
Chased the same problem on my 67 (or it chased me). Never did get it figured out. Went back to incandescent. I'm too old for this shit.
chemnick is offline
post #9 of 15 (permalink) Old 09-13-2018, 04:35 PM
GTOJUNIOR's Avatar
Quoted: 64 Post(s)
FWIW; Been using the 2357R for about a year now much improved light out put with NO side effects to stock system.
Name:	RED LED 1.jpg
ID:	115405   Click image for larger version
Name:	66 LED BULD TEST 3.jpg
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
post #10 of 15 (permalink) Old 06-20-2019, 10:04 AM
michaelfind's Avatar
Quoted: 12 Post(s)
Did you change only the rear bulbs to LED, or front and rear? I'd like to change the rear only but did not know if that was possible. Thanks for the pictures. Very helpful.
michaelfind is offline
Pontiac GTO Fog Light LED Bulbs! USA Made SLF Model! Plug & Play Install! Diode Dynamics Diode Dynamics 20 06-18-2018 07:55 PM
Pontiac GTO Reverse/Backup LED Bulbs! Plug & Play Install! Ships Same-Day! Diode Dynamics Diode Dynamics 28 06-18-2018 06:22 PM
1157 A BULBS for 67 GTO Eric Animal Diode Dynamics 23 05-19-2016 07:47 AM
Lumen replacement LED bulbs carid CARiD.com 0 10-21-2014 05:15 AM
Help with LED tail lamp reverse and blinker bulbs. Copasetic Exterior Discussions 1 01-15-2009 07:31 PM
