1157 LED bulbs for my '66 GTO - Page 2 - Pontiac GTO Forum
 6Likes
post #11 of 15 (permalink) Old 06-20-2019, 07:23 PM
Quoted: 347 Post(s)
Originally Posted by michaelfind View Post
Did you change only the rear bulbs to LED, or front and rear? I'd like to change the rear only but did not know if that was possible. Thanks for the pictures. Very helpful.
You should be able to just go with LED at the rear with no issues. I used a mix of LED and filament bulbs on my brother's truck - no issues.
You most likely will have to change your flasher unit to a newer electronic style flasher. I also did this on my brother's truck.
There are different styles of 1157 LED bulbs with regards to the placement of the LED chips. I use an online supplier called Super Brites LED https://www.superbrightleds.com/cat/...acement-bulbs/ You can check out the offerings as to the different types/styles. They provide dimensions and the angle that the LED light will project its light. Some of the "towers" may actually be taller than the standard filament bulb, so you may want to measure. If too tall, they have "mini" which is shorter.
You will see several offerings to choose from, like cool, natural, & warm. I thought the number you see with each box, ie 6500, 4000, 2950, was the brightness level. I found out not so. The "natural" is what you want if going with a clear/white light as it is the brightest of the three choices. The colored choices are what they are. You will see the lumins which is how bright they are.
Never had any problems and they ship very fast. So just a choice to take a look at.
michaelfind likes this.
post #12 of 15 (permalink) Old 06-21-2019, 04:20 AM
GTOJUNIOR's Avatar
Quoted: 64 Post(s)
Yes just the Bulbs on the rear.
I will add that I also applied a coat of High Temp Flat White paint to inside of the housing.
This worked far better then any Silver to help increase output.
michaelfind and Bald Menace like this.
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
post #13 of 15 (permalink) Old 06-22-2019, 04:18 PM
baba67's Avatar
Rear Leds
I used the Super Brites 1157 CAN Bus LED Bulb - Dual Function 30 SMD LED Tower - BAY15D Bulb - Red
Part Number: 1157-R30-CBT
I also upgraded with their led flasher relay.
I could not believe the difference, Absolutely worth the money.
If you have the age cracks in your lens as most of us do, these are awsome..
PontiacJim and michaelfind like this.
baba67 is offline
post #14 of 15 (permalink) Old 07-18-2019, 11:28 AM
John Schutt's Avatar
Quoted: 9 Post(s)
Two reasons for switching to LED:
1) safety, i can be seen much easier by people, first time i drove the car with wife following she stated the brake lights were dim, they were fine shes used to the brighter ones of today.
2) less drain on my old electrical wiring.
I'd like to discuss the the latter. I've noticed a light load resistor kit is required is required at each bulb to mimic the resistance of an incandescent. Doesn't this put the strain right back on the wiring?
https://www.superbrightleds.com/item...851&quantity=1
John Schutt is offline
post #15 of 15 (permalink) Old 07-19-2019, 10:39 AM
baba67's Avatar
Hi John
I did not add any load resistors to my 67 GTO taillights, just the replacement flasher and they work flawlessly.
No regrets here.
baba67 is offline
Pontiac GTO Fog Light LED Bulbs! USA Made SLF Model! Plug & Play Install! Diode Dynamics Diode Dynamics 20 06-18-2018 07:55 PM
Pontiac GTO Reverse/Backup LED Bulbs! Plug & Play Install! Ships Same-Day! Diode Dynamics Diode Dynamics 28 06-18-2018 06:22 PM
1157 A BULBS for 67 GTO Eric Animal Diode Dynamics 23 05-19-2016 07:47 AM
Lumen replacement LED bulbs carid CARiD.com 0 10-21-2014 05:15 AM
Help with LED tail lamp reverse and blinker bulbs. Copasetic Exterior Discussions 1 01-15-2009 07:31 PM
