Front sway bar bushings - Pontiac GTO Forum
post #1 of 2 (permalink) Old 01-17-2010, 09:46 AM Thread Starter
Finally tried installing new front sway bar bushings that were sitting around for years. They were aftermarket poly. The brackets did not fit, they would not clear the idler arm. I purchased new brackets and bushings from Ames. The bushings that came are alot longer than the bracket. They protrude out from the bracket about 5/8". The bracket screw holes mount flush to the frame if I remember correctly. I emailed Ames about it and they said to get them started and use a jack to take up the rest. Does this sound right to you guys? Its been quite a long time since I removed the sway bar and dont remember what the original bushings looked like. I tried stepping on the bushings to see how much they give and they didn't budge much at all--I weigh 235 lbs---maybe the cars weight will do it??
Gremlin66 is offline
post #2 of 2 (permalink) Old 01-18-2010, 02:09 PM
67 Basket Case Restorer
Too Many Projects's Avatar
Here's the bushings I got from Ames. They appear to be a direct replacement except for the excessive length of the bracket mounting surface. I may end up cutting the extra off.
Mitch
1967 Camaro ss/rs 350
1966 Chevelle SS 396
1966 Chevelle Malibu
1970 Chevelle SS 396
1962 Impala SS
1952 Chev 2 ton flat bed
1938 Chev coupe
Too Many Projects is offline
Rear Sway Bar CTCarGuy 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 3 11-17-2009 04:24 PM
Sway Bar Links? PEKO Drive train, suspension, alignment and brakes. 1 09-07-2007 09:09 AM
Bent Sway Bar Endlinks Groucho Drive train, suspension, alignment and brakes. 1 09-16-2006 01:04 PM
Popping noise coming from anti-sway bar on front gtoidiotswitch Drive train, suspension, alignment and brakes. 1 02-13-2006 07:46 AM
Sway bar dgoat4me 2004-2006 GTO General Discussion 6 01-02-2006 06:05 PM
