Fuse box no power - Pontiac GTO Forum
post #1 of 3 (permalink) Old 06-19-2019, 04:19 PM Thread Starter
Fuse box no power
Ok. Here it goes, 68 gto 400 4 spd. Points dist. I had it running. All was good but as it idled it shut down. I have no power to anything into the car. Fuse box, lights, ignition switch, literally nothing going into the car. I do have power from the battery to the starter. I test the starter and it operation. it’s good. I’ve been tracing and checking wiring with an ohm meter to see if maybe there’s a disable link that went south on me. Haven’t found it yet. Could the fuse box have burned out ? I expected to find or see a 12v power source going to the fuse box from somewhere under the hood ( battery or starter?) but nothing yet. I was going to run a bypass wire from the battery to the battery tab on the back of the ignition switch to see what powers up but haven’t done that yet. I did however check the ignition switch with a meter and all positions seem to operate as they should. Sorry such a long thread, hope I have enough info. I’m sure I forgot something. LOL
Warren 70 is offline
post #2 of 3 (permalink) Old 06-19-2019, 05:59 PM
I would start with the wire from from the starter to the bundle of wires above the manifold, in that bundle are the wires feeding the fuse block and connecting to the alternator, you probably have a loose connection.
05GTO is online now
post #3 of 3 (permalink) Old 06-20-2019, 04:17 PM Thread Starter
Thanks for the info and the wire diagram!! This will help greatly. When I find the issue I will post what it was, where and the resolution. 👍😎👍
