Generator vs valve-cover...... - Pontiac GTO Forum
 1Likes
  • 1 Post By kobold
post #1 of 7 (permalink) Old 07-24-2019, 12:28 PM Thread Starter
Quoted: 6 Post(s)
Hello guys,
once again, I have a Problem with my 1968 Le Mans.
Next winter, I want to install aluminium valve covers (with Pontiac logo) instead of the old ones.
Now I saw, that there is no clearence between Generator and valve cover.
When loosen the srew and turning the Generator a little bit, there's no more place between cover and Generator. (so it won't help buying a longer belt...)
Do you have any idea ? Maybe install a new (100 Amps) generator ?
Which will fit ?
Maybe other brackets ?
Please have a look at the pics.
Regards: Peter
kobold is offline
post #2 of 7 (permalink) Old 07-24-2019, 12:41 PM Thread Starter
Quoted: 6 Post(s)
now the pictures...
Name:	Lima Anschluss Ventildeckel klein.jpg
ID:	120525   Click image for larger version
Name:	Lima Halter klein.jpg
kobold is offline
post #3 of 7 (permalink) Old 07-24-2019, 04:05 PM
BLK69JUDGE's Avatar
Quoted: 57 Post(s)
somebody put a non pontiac alternator on your car ...
the 2 halves look to be not clocked correctly
the square plug to the regulator should be at the top of the back in the
snug belt location ...
looks like its 1/4 turn off
back needs to be turned 1/4 turn counter clockwise so the plug and the adjuster bolt are in line
BLK69JUDGE is online now
post #4 of 7 (permalink) Old 07-26-2019, 10:44 AM Thread Starter
Quoted: 6 Post(s)
Thanks a lot.
I gladly found (for a small dollar / Euro) a new alternator with the plug at 12°° position here in germany...
Thanks for the help !
kobold is offline
post #5 of 7 (permalink) Old 08-07-2019, 11:57 AM Thread Starter
Quoted: 6 Post(s)
Hello guys,
now I have the exact (new) alternator, and I have a new problem:
Voltage is constant at 15,2 Volt. I changed the voltage regulator and this happend:
First, voltage at 12 volts, increasing up to 17 volt during 20 seconds....
The generator lamp lights.
I opened both regulators, and inside, they seem to be the same....except one screw at the old one.
With this screw, it's possible to rise the force of the spring at the coil.
So, I think I can adjust the regulator ?
Did anyone do this before ?
regards: Peter
kobold is offline
post #6 of 7 (permalink) Old 08-07-2019, 11:59 AM Thread Starter
Quoted: 6 Post(s)
Picture from the regulator....with adj. screw marked green.
Name:	Spannungsregler einstellbar.jpg
kobold is offline
post #7 of 7 (permalink) Old 08-07-2019, 02:34 PM Thread Starter
Quoted: 6 Post(s)
...solved the problem:
new regulator is junk ( t I think, one coil doesn't switch exactly, contacts to wide. Could bent a little bit, but it's too much risk..)
I adjusted the voltage with the screw by reducing the spring-tension. Left turn, reducing voltage...
Now regulates to 14,4 volt.
Maybe during winter time, I'll think about an solid state regulator.
Does anyone have the exact model-number for a solid state regulator ?
Regards: Peter
deanhickey likes this.
kobold is offline
