Headlights Flickering - Pontiac GTO Forum
post #1 of 4 (permalink) Old 05-15-2019, 10:31 AM Thread Starter
Quoted: 6 Post(s)
I just got my 1970 GTO back from the shop where, among other things, a complete American Autowire wiring harness was installed. Prior to that I had converted the old headlights to H4 conversion, with no issues. Now, after getting the wiring harness, the lights flicker and turn off/on ONLY when I switch to high beam. ALL FOUR lights are affected. When I switch back to low beam the problem goes away.
A knowledgeable friend says the problem is most likely with the high/low beam floor switch. Another person recommended installing a resistor.
What do you guys think? Could the high/low switch be affecting it by not being able to handle the current? Is there a high current switch on the market? I look forward to your responses, except the "take it back to the shop" responses... :-)
bvcg1 is offline
post #2 of 4 (permalink) Old 05-15-2019, 02:40 PM Thread Starter
Quoted: 6 Post(s)
Well it's not the dimmer switch. I replaced it and still the same issue.
By the way, it happens whether the car is running or not. That would rule out the alternator wouldn't it?
bvcg1 is offline
post #3 of 4 (permalink) Old 05-15-2019, 03:12 PM
Lemans guy's Avatar
Quoted: 37 Post(s)
I agree not the alternator if it happens when it is off. You have a headlight switch on the dash and a high beam floor switch, you replaced one the other bears checking, probably some high resistance in a wire under the dash, when. The high beams go on too much current Thor the wires.
I run all my headlights on relays, simple to do and puts full power from alternator/ Battery to the headlights, the weak signal from the switch can stay weak as the relay will close with about 6Volts and 1.5 volts will keep it closed, but the headlight stays real bright gets full power.
You can do it under the hood and not under the dash if you prefer, but it is not”stock” wiring...
Lemans guy is online now
post #4 of 4 (permalink) Old 05-15-2019, 05:00 PM Thread Starter
Quoted: 6 Post(s)
Thanks for the reply and input. Both the headlight switch and dimmer switch are new. The headlight switch has been replaced twice because the one that came with the harness 'let go' of the knob and it wouldn't lock back in to place when I tried to replace it. I guess that spring-loaded button that holds the knob in had failed. So I guess I can rule out the switch as well. Where can I learn about installing the relays? How and where to install?
bvcg1 is offline
LCD Flickering johnfin Interior Discussions 0 02-03-2016 06:55 AM
'67 GTO lights flickering pjw1967 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 16 05-19-2014 02:58 PM
Ebay Projector Headlights (Sonar) VS. Spyder Projector headlights........... Iron Indian Exterior Discussions 1 06-27-2011 10:24 PM
Switching from hidden headlights to non hidden headlights 69-JUDGE 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 14 11-20-2009 08:24 PM
'68 gto vacuum headlights gto-pete 1964-1974 Tempest, Lemans & GTO General Discussion 2 11-29-2004 11:33 AM
