Points or other ignition - Pontiac GTO Forum
post #1 of 32 (permalink) Old 04-22-2012, 07:47 AM Thread Starter
I have purchased a 65 GTO. It has a 70 455 with the 66 Tri Power set up. The car has the factory points Ignition in it. The guy that owned the car before me said he never had any performance issues with the engine with the points. I thought about putting an HEI Distributor in the motor, but it wont clear the rear Carburetor. Considering that I will not be racing the car and it will only be my good weather weekend driver, I think the points distributor will probably be fine. Anyone have any thoughts or advise on a replacement distributor. Thanks
timmyg is offline
post #2 of 32 (permalink) Old 04-22-2012, 09:35 AM
FlambeauHO's Avatar
Quoted: 8 Post(s)
I run HEI buy if you really can't clear it maybe try one of the Pertronix flamethrower solid state units, they keep everything OEM looking without the lovely dwell settings etc. Think they run about 70-80 bucks. I put one in my moms spitfire about 12 years ago.
http://m.summitracing.com/search/Dep...and/PerTronix/
FlambeauHO is offline
post #3 of 32 (permalink) Old 04-22-2012, 09:37 AM
FlambeauHO's Avatar
Quoted: 8 Post(s)
Looks like you would want the Ignitor unit not the flamethrower. Good luck!
post #4 of 32 (permalink) Old 04-22-2012, 12:42 PM
Quoted: 118 Post(s)
I've run nothing but stock points and condenser ignitions in all of my GTO's over the pat 33 years. 100's of thousands of miles of driving, with no issues. No reason to "upgrade". Just stay away from the "uniset" (combined points and condenser) and be sure to replace them every 15,000 miles or so when you do your tune up. I have seen and I have heard of a lot of reliability issues with "upgraded" ignition systems....and these are issues that leave you stranded. The advantage of HEI is "no maintenance" I've seen more than my share of bad modules and magnetic pickup coils in other people's vehicle's. For a street driven, real world car, original is hard to bead.
post #5 of 32 (permalink) Old 04-22-2012, 12:52 PM
What he said, and I run an HEI in my car. For how you plan to use the car, there's no reason that a well maintained points system won't be just fine.
post #6 of 32 (permalink) Old 04-22-2012, 04:18 PM Thread Starter
Thanks for the replies. I have gotten some really good help from this Forum.
timmyg
timmyg is offline
post #7 of 32 (permalink) Old 04-22-2012, 06:50 PM
jetstang's Avatar
I like the HEI myself as an upgrade, as you can get parts at any store for it. Boats still like points as you can just sand the points, regap and get it running again. Your stock dist is 46 years old, so at least make sure the shaft is tight and advance weights work correctly. I would upgrade to the Pertronixs for the hotter spark and wider gap, incresed performance. Back in Highschool I used Sorensen cross cut points and threw the lightest advance springs in and it was a tire shreader, 66 tempest 455.
Burning rubber since 1982!!
jetstang is offline
post #8 of 32 (permalink) Old 04-22-2012, 08:08 PM
FlambeauHO's Avatar
Quoted: 8 Post(s)
I hate points, the only thing I hate more than points is dual points... maybe I am jaded because I could never afford new points for my motorcycles as a child. Always with the Emory cloth or Bristol paper. I am all about solid state, to me it can't be beat. Waterproof and always the perfect timing. I would pay 75 bucks any day of the week to spare myself the headache :-) just my 2 cents.
post #9 of 32 (permalink) Old 04-22-2012, 10:19 PM
jetstang's Avatar
Originally Posted by FlambeauHO View Post
I hate points, the only thing I hate more than points is dual points...just my 2 cents.
Pretty much the same as carb compared to fuel injection.. Carbs are cheaper, with injection you never have to adjust fuel ratio because the humidity changed or changed elevation. And the benefit of good fuel mileage. One perk, carb improvements are cheaper than injection, that's why I came back to old school.
jetstang is offline
post #10 of 32 (permalink) Old 04-22-2012, 10:20 PM
68greengoat's Avatar
I went with a Pertronix Ignitor III in place of the points. It has a built in rev limiter. I'm very happy with that setup.... They claim, "ignition box performance w/o the box"...
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
68greengoat is offline
Points to electronic ignition xcmac26 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 11 06-12-2009 04:18 PM
HEI instead of points auburnconsulting 1964-1974 Tempest, Lemans & GTO General Discussion 2 05-04-2009 03:25 PM
Any advise on Points? POOF 1964-1974 Tempest, Lemans & GTO General Discussion 10 05-03-2008 07:10 PM
Shifting points R.I.P. SVT 2004-2006 GTO General Discussion 1 05-26-2007 11:46 PM
launch points silgoat05 2004-2006 GTO General Discussion 4 07-24-2006 07:28 AM
