strange alternator wiring - Pontiac GTO Forum
post #1 of 12 (permalink) Old 04-24-2019, 08:51 PM Thread Starter
MJS69's Avatar
hi all...got a pic of the wiring on my sons 69 GTO alternator, it seems weird to me...the yellow wire goes to the battery, the red goes to the plug in and then to the electric choke, the black appears to go to the firewall, and the white is just clipped loose...does this seem weird? how should it be normally?
thanks
ID:	118549   Click image for larger version
MJS69 is offline
post #2 of 12 (permalink) Old 04-24-2019, 10:56 PM
BLK69JUDGE's Avatar
Quoted: 36 Post(s)
well
I will jump in .......
it looks like you have a 71 n newer alternator bracket ... 69 didnt have that rear bracket...
so
also it looks like its an internal regulated alternator ... also not available on a 69 ...
the clue is the flat plug in and not a square one...
yup
shes been hacked up .......... probably chopped up at the voltage regulator also
Scott
BLK69JUDGE is online now
post #3 of 12 (permalink) Old 04-24-2019, 11:21 PM Thread Starter
MJS69's Avatar
thanks for the reply....any thoughts on correcting the wiring or thoughts on why they would have wired it this way?
Mike
MJS69 is offline
post #4 of 12 (permalink) Old 04-25-2019, 05:33 PM
Quoted: 317 Post(s)
Mike
Who know why someone would hack the wiring. Maybe that Alt was a freebie and then they got on the internet and read how to hack up the wiring to get it to work.
Your options are to return the Alt/Voltage Reg/Wiring back to stock, or use the Alt with the built in voltage regulator and bypass the factory firewall voltage regulator with a jumper plug kit, or install a late model 1-wire Alt.
It is matter of original vs aftermarket and your skills at wiring.
This should be similar to what you have - Converting a Generator to an Internally Regulated Alternator - Wallace Racing
post #5 of 12 (permalink) Old 04-25-2019, 07:34 PM
Lemans guy's Avatar
Quoted: 37 Post(s)
Right and if you are not making a choice to remain original you may want to consider the MAD Electrical wiring kit. Mark Hamilton of MAD is an expert on GM wiring of the era. You can Google some of his stuff and you can call him.
I use his kit and it is awesome, he improves every bit of the factory wiring. Now original is OK and will work, but like PJ said the key decision is original or not.
And MArk is an alternator expert, you can read his papers on line, he knows hot rods and his kits are well worth it.
Lemans guy is offline
post #6 of 12 (permalink) Old 04-26-2019, 07:34 AM
GTO44's Avatar
Quoted: 35 Post(s)
White wire should go to the ALT or GEN light on the dash. The red wire is looped back on the back battery post to “self regulate” the alternator.
Simple diagram: https://encrypted-tbn0.gstatic.com/i...rUcZnXU5QDGiAQ
2006 GTO M6
Motor - Stock with Vararam
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
12.81 @ 110.6 2.03 60'
GTO44 is offline
post #7 of 12 (permalink) Old 04-26-2019, 02:51 PM Thread Starter
MJS69's Avatar
thanks for the replies everybody! goal for the time being is just to have the car running safely and reliably. The voltage regulator on the firewall appears to be bypassed all together, nothing hooked up to it at all. The GEN light does come on when starting the car and then goes off like it should, not sure how it's wired into the system lol. Tested the battery with a multimeter, 14.10 volts when the car is idling, so the alternator appears to be charging....the car has an aftermarket tripack of guages, one of them being alt. volts, not working, can I rUn the white leaf from the alt. to this guage?
thanks again
Mike
MJS69 is offline
post #8 of 12 (permalink) Old 04-26-2019, 09:30 PM
GTO44's Avatar
Quoted: 35 Post(s)
thanks again
Mike
Not quite sure how the Gen light is working without that white wire hooked up lol. But yes the factory voltage reg is bypassed because of the red wire looping to the back battery post of the alt which puts the alternator in self regulate mode. Clearly the charging system is working if you’re getting 14 volts when the car is running. If you have a regular ‘ole parts store voltage gauge, any 12 volt accessory (Key on) power source will work. Dont use that white for that purpose
2006 GTO M6
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
GTO44 is offline
post #9 of 12 (permalink) Old 04-26-2019, 09:37 PM Thread Starter
MJS69's Avatar
thanks for the reply! lol yeah I have a feeling the wiring is going to be a challenge with this car lol
MJS69 is offline
post #10 of 12 (permalink) Old 04-27-2019, 10:25 AM
1968gto421's Avatar
Quoted: 69 Post(s)
Here's MAD's web site: MadElectrical.com - Mad Enterprises
and the electrical section: MadElectrical.com - Electrical Tech
I have used their products---Good stuff and excellent backup/tech advice. If you are not experienced with automotive electrics, I would contact Mark and talk with him, great guy.
1968gto421 is online now
Voltage regulator/alternator wiring questions RunninLeMans 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 08-16-2015 05:08 PM
66 GTO - Alternator Chatter/right alternator? Mikereps 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 13 04-20-2015 09:55 AM
67 GTO strange wiring problem mbspeed 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 08-07-2013 06:00 PM
Alternator Wiring hayes68gto 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 01-31-2013 09:59 AM
Strange noise while braking hard? ftlfirefighter 2004-2006 GTO General Discussion 6 01-27-2006 03:08 PM
