Temp sending unit - Pontiac GTO Forum
post #1 of 4 (permalink) Old 05-08-2015, 04:17 PM Thread Starter
Temp sending unit
Which temp sensor do i need for a 72 lemans 400ci. with idiot light.
Im getting mixed advice from everyones catalogs. I cant figure out if i need the single prong button style or the one with 2 terminals.
Thanks.
1972 Lemans Luxury 421/400
1968 Chevy Panel Truck 327/3 speed
62xxx original miles.
ZackD1212 is offline
post #2 of 4 (permalink) Old 05-08-2015, 04:45 PM
rickm's Avatar
Quoted: 5 Post(s)
look at the wire harness under the hood n see what type of connector it has. some old style sending units come with a kit to change the terminal style.
rickm is offline
post #3 of 4 (permalink) Old 05-08-2015, 05:33 PM Thread Starter
Motors been swapped at some point... Vin says it came with a 350. The connector is cut off and was taped up... It is a green wire. If I ground it, the idiot light comes on.
post #4 of 4 (permalink) Old 05-09-2015, 05:57 PM
For 72 models, the water temp temperature sending unit was relocated from the front of the intake manifold water crossover to a passage in the outer cylinder head. Green wire is correct. Believe the temp sending unit used a side slide in type sending unit, will ck one of my '72 LeMans partscars and post back.
oil pressure sending unit qwkvet 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 04-11-2015 02:34 PM
1970 gto Judge needs 3 prong temp sending unit qpb 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 06-13-2013 02:29 PM
Fuel sending unit Piedog 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 04-09-2013 09:14 AM
fuel sending unit question? 67 Lemans John 1964-1974 Tempest, Lemans & GTO General Discussion 1 11-16-2009 07:29 AM
A.C. car fuel sending unit asshauler 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 04-23-2008 12:07 PM
