Windage tray help. - Pontiac GTO Forum
 1Likes
  • 1 Post By TLT3269
post #1 of 4 (permalink) Old 07-31-2013, 08:28 PM Thread Starter
Windage tray help.
I know I've seen the answer to this once before but can't seem to find it now. Finally putting my 400 back together and am ready to put the windage tray back on, but am not sure what the best/correct way is to bolt it up after using ARP studs on the main caps instead of bolts... I have a few ideas that I'm sure would work, but would rather see what others know works first. Thanks guys.
TLT3269 is offline
post #2 of 4 (permalink) Old 07-31-2013, 08:37 PM
Just bolt it up as normal being sure to use a dab of silicone at the corners/joints at the heads and block.
post #3 of 4 (permalink) Old 07-31-2013, 08:47 PM Thread Starter
windage tray... not valley pan.
deanhickey likes this.
TLT3269 is offline
post #4 of 4 (permalink) Old 09-08-2019, 11:23 PM
Briankdau's Avatar
I know this post is from a long time ago but what did you do with your windage tray to get it to fit with the arp studs thank you
Briankdau is offline
Windage tray clearance Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 3 01-19-2011 10:52 AM
windage tray studs Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 13 01-12-2011 07:57 PM
3/4 vs full windage tray Topkat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 12-30-2010 05:17 PM
windage tray and a cam Topkat 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 1 12-04-2010 04:16 PM
windage tray/dipstick tube wytnyt 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 10-11-2008 05:26 PM
