411/911 Initial Start Up - Pontiac GTO Forum
post #1 of 1 (permalink) Old 05-23-2018, 10:02 AM Thread Starter
Just got my 1966 GTO with a 455ci bored .030 over, pro-charger (8lbs boost) put back together bottom end rebuild). I have a demon GT 750 carb. Tried the initial start up on it and "wants" to run but won't stay running. The ignition is from MSD Ready to Run and the coil is as well (Blaster 3) new plugs and the wires are Fire Core Ignition Wires by Rick Gorski. I had a machinist put in -22 pistons, valves cleaned, Mahle Pistons and rings and a Eagle crank. Firing order is correct with the specs. Any assistance? Did a bypass for the coil as well to help push more juice...Thanks MAD DOG In Rineyville, Ky
MAD CAV SCOUT is offline
  Pontiac GTO Forum > Off Topic Discussions > The Lounge
Initial Start Up Problems MAD CAV SCOUT Gtoforum.com Site Help 0 05-23-2018 09:52 AM
60 degrees of initial advance?? 65Poncho 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 36 04-07-2017 07:51 PM
Initial Timing Setting NEEDLEZ 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 6 07-21-2015 12:43 PM
Setting initial timing FlambeauHO 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 13 05-14-2012 11:16 AM
411 re: Flowmaster & K&N RudyDMY Intake and Exhaust Discussions 4 08-03-2009 04:57 PM
