remote programing - Pontiac GTO Forum
post #1 of 4 (permalink) Old 02-10-2005, 06:26 PM Thread Starter
remote programing
Does any body know how to program a new remote on a 04 GTO?
terry brennan is offline
post #2 of 4 (permalink) Old 03-15-2005, 02:46 PM Thread Starter
I Finally Found Out How. For Anybody's Info The Procedure Is, with The New Key Put It In The Ignition And Turn It To Run. After About 10 Min. The Horn Will Churp Once. Turn Ignition Off Then Back On. After 10 Min. The Horn Will Churp Twice. Turn Ignition Back Off And On. After Another 10 Min. The Horn Will Churp Three Times. Then Start The Car. It Should Start. Then Turn Off Car And Remotely Lock And Unlock Doors With The New Remote. This Will Not Remove Other Keys That Are Programed. NOTE: YOU HAVE 5 MIN. TO TURN THE CAR TO OFF AFTER THE CHURP AND 5 SEC. TO TURN IT BACK ON
post #3 of 4 (permalink) Old 03-15-2005, 02:53 PM Thread Starter
[QUOTE=terry brennan]I Finally Found Out How. For Anybody's Info The Procedure Is, with The New Key Put It In The Ignition And Turn It To Run. After About 10 Min. The Horn Will Churp Once. Turn Ignition Off Then Back On. After 10 Min. The Horn Will Churp Twice. Turn Ignition Back Off And On. After Another 10 Min. The Horn Will Churp Three Times. Then Start The Car. It Should Start. Then Turn Off Car And Remotely Lock And Unlock Doors With The New Remote. This Will Not Remove Other Keys That Are Programed. NOTE: YOU HAVE 5 MIN. TO TURN THE CAR TO OFF AFTER THE CHURP AND 5 SEC. TO TURN IT BACK ON.
post #4 of 4 (permalink) Old 03-15-2005, 02:55 PM Thread Starter
GOOD LUCK
  Pontiac GTO Forum > Off Topic Discussions > The Lounge
