Very good post about using your clutch properly - Pontiac GTO Forum
post #1 of 6 (permalink) Old 04-04-2007, 01:04 AM Thread Starter
Most of us obviously know the proper use of the clutch, but I noticed after reading this that I do abuse my clutch somewhat with laziness or poor driving habits. One such example is that I tend to downshift a lot, but fail to rev match the engine speed of the lower gear.
Its a very good read....
CLICK HERE
Bandit is offline
post #2 of 6 (permalink) Old 04-04-2007, 10:54 AM
CLICK HERE
EXCELLENT! Thanks for the post.
rcu316 is offline
post #3 of 6 (permalink) Old 04-04-2007, 12:14 PM
Send a message via AIM to MonaroGuy06
The downshifting with the rev-matching is called "Double Clutching"
Definitely a must for anything with a manual transmission!
GREAT POST...Thanks!
MonaroGuy06 is offline
post #4 of 6 (permalink) Old 04-04-2007, 12:21 PM
So wait a minute...This may be a dumb question but I'm wondering..The skip-shift programmed in our cars from 1st to 4th..Does that add "Extra" Weight and pressure to our clutch system??
Any help would be appreciated! Thanks
post #5 of 6 (permalink) Old 04-04-2007, 08:30 PM
Mike_V's Avatar
Actually, double clutching is just that, the clutch has to be engaged and disengaged twice with every gear shift. This was required on older vehicles and even some newer trucks before synchronized manuals were standard. An older Army truck I drove required this, and it was a PITA. Just try doing it for the hell of it. Shift into gear, then disengage clutch and out of gear, then engage clutch while in neutral, then disengage clutch and put in gear, then engage clutch. Yeah - fun.
For new cars, you donít have to match the RPM unless youíre really up there. Even then, you should let the engine RPM drop before taking it out of gear for a downshift. I donít care what that post says, but normal driving should not reach an RPM level that would be any problem for a downshift. If you hit your head on the steering wheel when you downshift, yeah, youíre doing it wrong.
Mike_V is offline
post #6 of 6 (permalink) Old 04-08-2007, 12:13 AM
oops... my poor clutch! Great thread.....
Joey R is offline
  Pontiac GTO Forum > Off Topic Discussions > The Lounge
