1/4 panel extension on 65 - Pontiac GTO Forum
post #1 of 12 (permalink) Old 04-18-2014, 05:46 PM Thread Starter
Quoted: 5 Post(s)
Ordered new 1/4 panel extension seals (old ones are incorrect and protrude above the surface). From previous threads, it looks like I'll need to lower the bumper, remove the tail panel trim.
Also will be installing new bezels. Any suggestions on getting the seals installed properly? Or anything else in this process? Any "might as wells" ?
65gto is offline
post #2 of 12 (permalink) Old 04-18-2014, 06:31 PM
rickm's Avatar
Quoted: 5 Post(s)
I just went through this on my '65 sports coupe. the seals that ames has I have a problem with. they are lengths of chanelled rubber strips that look like crap on the car, don't make the bends , and place the extentions so far back from the panel you can barely start the speed nuts on the studs. they claim "they are stock". im no expert, but ive been a gto lover since the mid '70s. ive NEVER seen a '65 gto with these gaskets. I threw them away n used a THIN line of black silicone sealer. what a nightmare I went through with these gaskets. they are just like the gaskets for the front headlight bezels, that mount fine on the car. ?????
rickm is offline
post #3 of 12 (permalink) Old 04-18-2014, 07:05 PM
crustysack's Avatar
+1 on the gaskets from ames, usually high quality parts from these guys but these gaskets did NOT work out at all. I ended up firing them in the trash and used some black sikaflex. i do not think anyone makes the "correct" gasket for this part
crustysack is offline
post #4 of 12 (permalink) Old 04-18-2014, 08:12 PM Thread Starter
Quoted: 5 Post(s)
Thanks guys, I bet that's what I have now that I want to replace. They are exactly the same as the headlights. I hope I get something better. Ordered off Ebay from Rubber the right way.
65gto is offline
post #5 of 12 (permalink) Old 04-19-2014, 08:04 AM
If you have the originals and they're not all solidified you can wash em good with dish soap to remove the crud, then clean em up with wax and grease remover. If they're too stiff after that then you can soak em in glycerine as found in wire lubricant (the stuff that helps wire slide through conduit). Most of them are trashed and I get how much of a problem new stuff can be, but I'd avoid silicone and use automotive strip caulk instead. The silicone will bond the part to the body and be a PITA if the day comes that you need to service the area in the future. Just a tip from my days with such issues. Might be a good place for another suggestion when it comes to rubber seals like for trunks and doors. In most cases they have too much grip, too good a seal that can prevent getting good fits panel to panel. A spray lube only serves to intensify the sealing characteristics, but dusting them off with talcum powder allows it to slide into a favored position. Any excess is easy to clean up and once embedded in the rubber it gives it a shiny OEM look. Hope that's helpful info.
666bbl is offline
post #6 of 12 (permalink) Old 04-20-2014, 07:40 PM
Joe'sToy's Avatar
I have gone through the same problem last year. What I ended up doing was buying the three quarter round rubber stripping that is used to re-screen a window or patio door.
If you bring a sample of the original with you, just match it to the various sizes at Lowes or Home depot.
If you are unsure of what I'm talking about. it's the rubber strip that is pushed into the channel to keep the screen material in the frame.
Once you have the right size, it will fit into the 1/4 extensions and you won't see it at all.
Joe'sToy is offline
post #7 of 12 (permalink) Old 04-22-2014, 02:15 PM Thread Starter
Quoted: 5 Post(s)
OK, dumb question, can I just lower the bumper enough to get the 1/4 panel extensions off, or do I need to remove it? Which bolts do I loosen.
65gto is offline
post #8 of 12 (permalink) Old 04-22-2014, 02:59 PM
rickm's Avatar
Quoted: 5 Post(s)
great idea, is it pliable enough to make the bends?
rickm is offline
post #9 of 12 (permalink) Old 04-22-2014, 04:16 PM Thread Starter
Quoted: 5 Post(s)
My concern is, if I remove the two rear bolts on the bumper brackets, will it swing down and miss the body? Or do I need to take the bumper off completely.
65gto is offline
post #10 of 12 (permalink) Old 04-23-2014, 06:49 PM
Joe'sToy's Avatar
It's very pliable, just to make it easier, I put the rubber strips in some boiling water and heated them up. Pulled them out, wiped down and with a few daps of RTV Black, filled the whole back channel on the 1/4 extensions. Once the RTV dried, I trimmed the ends. Just used one continuous piece, start at one end, then finish at the other.
Joe'sToy is offline
Where can i get this bumper extension? Willis_454 2004-2006 GTO General Discussion 1 07-25-2010 10:14 PM
1/4 panel extension reflectors olde-goat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 11 05-12-2010 10:23 PM
1965 Quarter Panel Extension Seal/Gasket? WideTrack 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 3 05-10-2008 07:50 AM
Sell front extension Gertythadirtygoat Exterior Discussions 0 07-12-2007 11:16 PM
Clutch Extension GTO_Gregory Interior Discussions 4 10-28-2006 08:31 PM
