1964 LeMans Turn Signals - Pontiac GTO Forum
post #1 of 5 (permalink) Old 06-16-2012, 05:51 PM Thread Starter
455LeMans's Avatar
Greetings gents, I'm new to the forum and the new owner (less than a week) of 1964 LeMans sport coupe. I'm in the process of fixing the many little things that need work.
One of the items that needs immediate addressing is the turn signals. There are no felt or audible clicks to engage the turn signals on the column lever and they don't cancel either.
Is the culprit for both of these conditions the turn signal cancelling cam? Like this one:
http://www.summitracing.com/parts/OPG-PF8231B/
I'm new at this and any help I can get from those who have boldly gone before would be greatly appreciated. By the way this is a non-tilt column with an aftermarket Grant steering wheel. Thanks.
455LeMans is offline
post #2 of 5 (permalink) Old 06-19-2012, 05:13 PM
TK69tempest's Avatar
Well - I'll take a stab at it - I'd say if the '64 is anything close to my '69, it's probably the switch itself instead of the cam. At least that was the way mine acted and it turned out to be the switch had cracked - it still worked, but it wouldn't "click" when you moved the lever and it wouldn't cancel when the wheel was turned...
TK69tempest is offline
post #3 of 5 (permalink) Old 06-19-2012, 06:01 PM
Some aftermarket wheels will not cancel, I know the one in Julie's `70 Beetle doesn't cancel either.
post #4 of 5 (permalink) Old 06-20-2012, 12:56 PM Thread Starter
455LeMans's Avatar
Thanks for the input guys. I was wondering if the steering wheel might be at fault. The horn doesn't quite work right either - sounds muted. Maybe I'll pull the wheel and see if the switch has indeed cracked.
post #5 of 5 (permalink) Old 06-23-2012, 06:36 PM
the switch needs to be checked out inside the column, but the cam must be matched to the switch if you just replace the cam.
pontiac is offline
turn signals Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 14 07-13-2011 08:21 AM
turn signals Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 8 05-14-2011 03:42 PM
'68 turn signals 68greengoat 1964-1974 Tempest, Lemans & GTO General Discussion 3 05-05-2011 09:18 PM
Turn signals not working - Need help! whysoserious Service, Maintenance and Technical Discussion 5 08-17-2009 03:17 PM
help with turn signals HoldenGTO Service, Maintenance and Technical Discussion 4 01-19-2006 06:15 PM
