1965 GTO AKA DIRT-GOAT "Restoration" - Page 2 - Pontiac GTO Forum
 10Likes
post #11 of 28 (permalink) Old 08-13-2018, 08:43 PM
Quoted: 404 Post(s)
Looks great. Personally, I like the "rough" look versus a restored shiny exterior. Looks like it stepped out of the '70's. I would not do much with the body and the misalignment........ goes with the rest of the car and I would not work to hard to get it that perfect. You will turn a lot of heads just the way it is.
post #12 of 28 (permalink) Old 08-14-2018, 08:15 AM
Quoted: 162 Post(s)
I'd recommend flushing your system many times with water before installing the new radiator . While I know that sounds obvious, many don't and the vast majority don't flush enough....
My aluminum radiator, clutched fan and poorly designed / manufactured AMES shroud, and 180* thermostat keep the car right around 180 - 195.
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is offline
post #13 of 28 (permalink) Old 08-14-2018, 09:23 AM Thread Starter
Thanks Jim! Exactly the reaction I'm hoping for with this project.
Thank you for the reassurance with the body panels... a lot on this car is just killing my OCD, but I couldn't agree more with you.
DIRT-GOAT is offline
post #14 of 28 (permalink) Old 08-14-2018, 09:39 AM Thread Starter
Thanks for the reminder!
I spent a bit of yesterday researching cooling system options.. Figured maybe since I'll be starting "fresh" might want to do some upgrading (electric fans, water pump, evans coolant, etc.). However the bit I had her running (before the hole in the radiator) she was staying right at 190* during the engine timing/carb tuning phase and long idle times in the garage. Granted, I didn't get a chance to drive her around much to get "real world data" to witness any temperature fluctuation. But I think i'm just going to ensure a good flush, run 50/50, and just change the radiator. Which I ended up going with a cold case aluminum from Butler Performance.
Does anyone have any other coolant recommendations based on experiences?
post #15 of 28 (permalink) Old 08-14-2018, 10:01 AM
the65gto's Avatar
Quoted: 12 Post(s)
Thanks for taking us along on your project, looking forward to more pics etc.
the65gto is offline
post #16 of 28 (permalink) Old 08-14-2018, 04:54 PM
Cafr119's Avatar
Quoted: 38 Post(s)
Yeah, I like the looks of it, really liking what your doing and the suspension work !!!
Cafr119 is offline
post #17 of 28 (permalink) Old 08-15-2018, 12:46 AM
Quoted: 162 Post(s)
The radiator shroud, clutched fan, and 50/50 with a 180* and aluminum thermostat should work great (that is my setup). You can add water wetter if you want, but I suspect you'll be more than fine without it.
DIRT-GOAT likes this.
Current setup:
4 speed Muncie
cij911 is offline
post #18 of 28 (permalink) Old 08-15-2018, 09:00 AM Thread Starter
Thanks!
Thing should handle like a dang Miata when I'm done!
post #19 of 28 (permalink) Old 08-15-2018, 09:47 AM
Quoted: 162 Post(s)
Thanks!
Yeah like a Monster Miata ! (Fun car to drive by the way .....)
Current setup:
4 speed Muncie
cij911 is offline
post #20 of 28 (permalink) Old 08-20-2018, 11:25 AM Thread Starter
Hi everyone! I was lucky to have a chance over the weekend to flush the cooling system and install the new radiator. The Cold Case aluminum radiator is definitely a quality product, and would recommend. My only issue was that the fill was on the driver versus passenger side. Not that it's really an issue, but was just an unexpected head scratching moment. Luckily it appeared the radiator support is configured to accept the factory bracket on either side of the support .
With the new radiator installed and system filled, I was able to take her out for a nice stroll up the road and back. A few looks from the neighbors at 8:00am running open header and hood off
This weeks project list is to undercoat the body and then get the exhaust fitted. Then I'll start on the interior.
As far as mechanical side of the dirt-goat, or "gremlins" found so far and will be address as time permits:
-Vacuum leak on the line from brake booster to intake manifold
-Passenger side caliper is making quite the screech. Just want to verify it is something with the pad/rotor and not the hub.
That's really about all I noticed ... which isn't bad at all. The temperature was staying right at 180* on my short drive after a 10 minute idle warm up. No fluids leaking or brake failures. The disc brakes up front feel amazing in this thing. An obvious night/day difference over front drums.. which everyone knows already. I can't wait to lay into the turns to test out the new suspension, along with the new rubbers 275/60R15 Nitto 555 in the back. Hopefully I'll be able to get one nice run around town before winter comes LOL
I'll update later this week or next week as I go along. I've got a few projects around the house and my spare vehicle needs some love so I can get her ready to sell .. anyone want to buy a 2001 Jeep Cherokee
cij911 likes this.
Meineke "glasspacks" installed on '04... GREAT sound, dirt cheap Stephen Hopkins Intake and Exhaust Discussions 0 03-27-2006 01:50 PM
Exterior colors, dirt, and spot cleaning Clueless Exterior Discussions 13 03-20-2006 10:40 PM
oily big blocks "aka recall" cztmgto Service, Maintenance and Technical Discussion 8 03-08-2006 10:06 PM
Joe Dirt's GTO..... GTODEALER The Lounge 14 11-22-2005 09:02 AM
Big MoFo Dirt Devil TexasRealtor The Lounge 0 11-26-2004 02:42 PM
