1965 GTO bolt identification - Pontiac GTO Forum
post #1 of 7 (permalink) Old 11-14-2011, 09:45 PM Thread Starter
I am working on a basket case that has about 50% Hardware store bolts. Is there anyone out there that has made a list of bolts showing the size, grade, head marking, and location of chassis bolts, sheet metal bolts, and engine compartment bolts. Thanks in advance. Any info will be appreciated.
trifidave is offline
post #2 of 7 (permalink) Old 11-18-2011, 12:31 PM
never seen such a list published.
pontiac is offline
post #3 of 7 (permalink) Old 11-18-2011, 12:39 PM
Quoted: 102 Post(s)
Me niether. The best bet would to able to see a friend's car or club member's car and determine what you need. Lowes has an automotive bolt and fastener section, and they have a LOT of the black finish bolts for fenders/core supports/ etc that are the same as the original stuff. Not real pricey, either. The vendors carry item-specific bolts. Junkyards are agood source, too, if you are ----whoops----you're in Ohio. Nix on the junkyard bolts.
post #4 of 7 (permalink) Old 11-18-2011, 06:20 PM
When in doubt...use the appropriate size GRADE 8 bolt.
Eric Animal is offline
post #5 of 7 (permalink) Old 11-19-2011, 03:00 PM
not good to use grade 8 bolts in all locations, much of factory body bolts and such were grade 5, engine bolts were also 5, except for heads, fine thread, and studs \ nuts. the 12 point for the fuel pump is because it is tight spacing, the bolt head is undersized for the shaft diameter hence the 23 point, and this allows a socket to be used to get the pump on and off.
pontiac is offline
post #6 of 7 (permalink) Old 11-25-2011, 12:06 AM
Some of the bolts did not make a lot of sense, like 12 point bolts holding on the fuel pump. If you can figure out what you need, many are available from specialty manufacturers, or go to mcmaster.com for a wide range of fasteners. I don't work for them.
Knuckledragger is offline
post #7 of 7 (permalink) Old 11-25-2011, 07:09 PM Thread Starter
Thanks for the replies guys. I just found out about an original car in my area that is being taken apart and the owner is willing to let me look at it.
69 GTO engine identification help......... Eshack80 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 4 12-14-2010 04:08 PM
Is the 10 Bolt 8.2 BOP Carrier the same as Chevy 10 Bolt? mighty454 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 6 04-21-2010 03:30 PM
Help rim identification sjd73ss Wheels and tires 5 11-09-2009 02:38 PM
10 Bolt Versus 12 Bolt Rear Axle take5 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 10 09-28-2009 03:45 PM
Rim Identification Karbon 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 14 06-13-2009 06:10 AM
