1965 gto rear tailpanel - Pontiac GTO Forum
post #1 of 3 (permalink) Old 04-18-2016, 03:34 PM Thread Starter
Any way to repair a broken mounting stud on a 1965 GTO rear tailpanel? its the end one so panel sticks out past bezel. Its a pretty nice panel but needs a stud.
army6741 is offline
post #2 of 3 (permalink) Old 04-19-2016, 04:16 PM
I'm not sure which piece your talking about, but I'm guessing it's the pot metal on the tail light? If the stud is on the sheet metal panel extension you can weld a new stud on. If you are talking about a die cast pot metal piece then you can repair it with muggyweld super alloy 1.
Aluminum Welding & Aluminum Repair | MuggyWeld.com
Check out some of the youtube videos on repairing die cast.
1964SS is offline
post #3 of 3 (permalink) Old 04-19-2016, 09:53 PM
crustysack's Avatar
any thick epoxy will fix it, jb weld, gm carb epoxy, proset 176/276 super tough, spa bond 345 toughened. you can braze the stud back on but be VERY wary of distortion on the finish side
crustysack is offline
1965 GTO Rear axle needed 19GTO65 1964-1974 GTO's and Parts Wanted 2 05-02-2018 04:10 PM
1965 GTO rear end johns1965gto 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 2 09-11-2014 08:21 AM
1965 gto convrtible rear seats ucaddoc 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 08-09-2014 07:35 AM
How do I fix rust around rear window of 1965 GTO dlloyd Exterior Discussions 2 08-05-2012 08:03 PM
P_O_N_T_I_A_C Letters on Tailpanel 05GTO 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 10-27-2008 01:29 PM
