1965 GTO wiper linkage repair - Pontiac GTO Forum
post #1 of 4 (permalink) Old 05-31-2017, 09:07 AM Thread Starter
I am restoring a '65 GTO and need some help on repairing the wiper linkage/transmission. The plastic ball retainer on the main joint failed and no longer holds the linkage ball. I ordered a "repair kit" off ebay, but came with no directions, and the seller won't get back to me. It comes with copper parts, and screws and nuts, but I don't see how it assembles and repairs the linkage. Anyone have any history on using these repair kits? thx!
Don
ID:	91617   Click image for larger version
Name:	Wiper Linkage.png
2ocnorb is offline
post #2 of 4 (permalink) Old 05-31-2017, 02:57 PM
GTOJUNIOR's Avatar
Quoted: 64 Post(s)
With that kit you need to drill out the factory rivets that retain the ball/joint.
Those are metal balls attached to the spline portion, hopefully not worn down and/or damaged.
Below is a '66 linkage but will apply to the '65 as well.
You can buy the complete linkage if needed.
Name:	WIPER-ARM LINKAGE 1.jpg
ID:	91633   Click image for larger version
Name:	WIPER-ARM LINKAGE 2.jpg
ID:	91641   Click image for larger version
Name:	WIPER-ARM LINKAGE 3.jpg
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
post #3 of 4 (permalink) Old 06-14-2017, 10:05 AM Thread Starter
Thanks, but how do the new parts assemble? I drilled out the rivets and pulled out the broken plastic ball retainer. I can't see how these new parts assemble into the old parts.
2ocnorb is offline
post #4 of 4 (permalink) Old 06-14-2017, 12:42 PM
64GTOConvertible's Avatar
Quoted: 17 Post(s)
See Junior's "Picture 3" The 2 metal bits clamp over the ball so you can attach the linkage to the wiper arm base. If your ball is gone... ??? Time for replacement wiper transmission.
64GTOConvertible is offline
clutch linkage repair Chris-Austria 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 6 02-07-2014 09:01 PM
67 GTO Column Shift Linkage kjk990 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 05-10-2012 12:06 PM
67 GTO door lock linkage Black68GTO 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 8 08-31-2011 10:42 AM
1965 clutch linkage bracket Pontiac Tempest Cstm 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 03-23-2010 07:46 PM
