1965 speedometer - Pontiac GTO Forum
post #1 of 8 (permalink) Old 09-11-2014, 12:00 PM Thread Starter
1965 speedometer
can anyone tell me easiest way to remove speedometer needle from one speedometer and attach to another. I assume its a press fit. Do not want to damage needle removing. Thanks.
army6741 is offline
post #2 of 8 (permalink) Old 09-11-2014, 01:12 PM
Should be able to just remove it. May be a small screw in the back
1965goat is offline
post #3 of 8 (permalink) Old 09-13-2014, 11:13 AM
tiger13's Avatar
Here is some instructions that helped me do mine on a 67 Le Mans, your should be the same once you take the speedometer Gage out.
Rusty in NC
tiger13 is offline
post #4 of 8 (permalink) Old 10-07-2014, 06:49 PM Thread Starter
thanks tiger13. I have speedometers rom a 65,66,67. looks like they are all the same.
army6741 is offline
post #5 of 8 (permalink) Old 10-07-2014, 10:35 PM
Quoted: 5 Post(s)
You might take a minute and call Pete Serio. You should be able to find him by googling his name. He knows everything there is to know about Pontiac speedometers.
65gto is offline
post #6 of 8 (permalink) Old 10-08-2014, 09:10 AM
Quoted: 117 Post(s)
X2! SUPER easy to break off the needle/screw up the speedo head. And then you'll be buying another unit. Personally, I would not mess with it.
post #7 of 8 (permalink) Old 10-09-2014, 08:00 AM
allpawl66's Avatar
It just pulls off , it need parts let me know .
allpawl66 is offline
post #8 of 8 (permalink) Old 10-09-2014, 03:46 PM
Goatnut's Avatar
Nothing to fear. Removing the needle will not mess up your speedo. They are simply pressed onto the speedo shaft. Some will just pull off. I had one where I had to leverage from behind the needle with thwo right angle screw drivers. That scratched the guage face but I had a replacement. When you reinstall the needle, have it clocked to anywhere above "0". After it is pressed on you can rotate the needle counterclockwise to set the needle at "0".
1947 Chevy "Art Deco" PU
1964 Chevy Custom C20
1965 Tempest Wagon
1967 GTO
1972 Lux Lemans 2D
Goatnut is offline
1965 speedometer army6741 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 2 08-30-2014 06:54 AM
How to remove speedometer from a 1965 GTO riggsjr 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 07-05-2014 03:36 PM
speedometer Q8 GTO 2004-2006 GTO General Discussion 12 07-16-2009 10:08 PM
Speedometer mdilello 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 08-08-2007 09:54 AM
Speedometer off aryanramsey Drive train, suspension, alignment and brakes. 9 03-14-2007 12:21 AM
