1965 Tri power Choke Question - Pontiac GTO Forum
 1Likes
  • 1 Post By PontiacJim
post #1 of 9 (permalink) Old 04-14-2019, 01:41 PM Thread Starter
Quoted: 12 Post(s)
]Having a problem with my engine running to rich. Tried adjusting the choke but I think something is missing. I have added a picture and as you can see the choke is capped off with a piece of tubing. Has been this way for the 40 years I have owned the car. Does cometning go on the end that is capped off ? Thanks
keiko is offline
post #2 of 9 (permalink) Old 04-15-2019, 06:33 PM
Quoted: 404 Post(s)
Ton of images on the internet which will show you. I assume your 1965 Service Manual would show this as well.
I attached a web shot of a '65 Tripower that should answer your question. Just click on the image.
Name:	1965 GTO Tripower.jpg
post #3 of 9 (permalink) Old 04-15-2019, 06:42 PM Thread Starter
Quoted: 12 Post(s)
Well unfortunately I dont have a service manual, but looking at the picture it doesnt seem that my choke can be working properly. Would like to get more info on how to fix this. Your pic appears that the choke is drawing manifold vacuum
keiko is offline
post #4 of 9 (permalink) Old 04-15-2019, 06:50 PM
Quoted: 404 Post(s)
No, that is the exhaust heat crossover that goes under the carb - no vacuum. You can get a Service Manual on CD or a reprint from Ames Pontiac or even Ebay.
keiko likes this.
post #5 of 9 (permalink) Old 04-15-2019, 11:17 PM Thread Starter
Quoted: 12 Post(s)
Thank you
keiko is offline
post #6 of 9 (permalink) Old 04-15-2019, 11:19 PM Thread Starter
Quoted: 12 Post(s)
One More Thing, I just looked at my manifold, there is no holes for the tubes in the manifold. I must have a different manifold. Maybe a 66
keiko is offline
post #7 of 9 (permalink) Old 04-16-2019, 08:38 AM
Quoted: 162 Post(s)
If you need any parts, call Jon or Mike @ Pontiac Tri Power https://pontiactripower.com. They are super knowledgeable and friendly and will have whatever you want / need for your setup. In addition, they do rebuilds.
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is offline
post #8 of 9 (permalink) Old 04-16-2019, 08:51 AM Thread Starter
Quoted: 12 Post(s)
great info thanks, will call them
keiko is offline
post #9 of 9 (permalink) Old 04-16-2019, 11:32 AM
Lemans guy's Avatar
Quoted: 79 Post(s)
If you want it original you have to go that route, but an easy change is to an electric choke, they pop right on one wire to key on power..
Very easy and they run well, heats electrically rather than from the exhaust crossover. A manual choke is easy as well.
Lemans guy is offline
Running a built 421, 65 GTO, Tri-power, considering a 66 Tri-power setup avman 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 4 07-28-2018 11:46 AM
66 tri power choke CPL 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 6 04-16-2018 12:04 PM
Tri-power choke tubes trimfixer 1964-1974 Tempest, Lemans & GTO General Discussion 1 08-31-2014 10:37 PM
