1966 GTO Build Thread....Frame off in progress... - Page 2 - Pontiac GTO Forum
 11Likes
post #11 of 32 (permalink) Old 06-15-2015, 02:50 PM Thread Starter
Originally Posted by Indy1K View Post
Saw your trunk repair. Can you tell me how you are joining the seams of the pan pieces and extensions together? I see the spot welds, are you welding the entire seam on both sides?
BTW, whose parts did you use?
Looks good so far!
Regards,
Kevin -Indy1K
I am using Goodmark for the trunk floor and supports. The center section has flanges to accept the side sections. I put spot welds (~every inch) on the top and welded all sections to the support below. I am not going to weld the entire seam. I used a grinder to knock down the spot welds and brushed the seam with POR-15. Once I get the interior floors done I am going to go back and blend all the joints so you will never see them.
SavetheGoats is offline
post #12 of 32 (permalink) Old 06-15-2015, 03:19 PM Thread Starter
Some more randoms here. Got the floors cut out last night. I have some work to do, but I plan to put the new floors in...2 weeks or so.
I have a new dash ready to go...and no it is not the one in the pic. The wheel well is a before shot. I have some fresh steel in there now. Sorry about that blurry floor pic....
As you can see I am scoring some free tools in the process. The trunk drop-offs were hiding some "nice" wrenches.
ID:	59842   Click image for larger version
ID:	59850   Click image for larger version
ID:	59858   Click image for larger version
ID:	59866   Click image for larger version
post #13 of 32 (permalink) Old 06-21-2015, 07:39 PM
Valsmere's Avatar
Your car your project ways I see it. I have a 67 that I was thinking about doing a LS swap but the cost kept me away. I can't wait to see yours done! Good luck for sure!
Sent from my iPhone using Tapatalk
The only easy day was yesterday.
Valsmere is offline
post #14 of 32 (permalink) Old 06-22-2015, 05:53 PM
Originally Posted by the65gto View Post
It just tick's me off to see how some people let an Ole Goat just sit there and let it deteriorate away in the first place. Glad you are bringing her back!
^This.
Better to be heavily modified than left to rot.
M1Lover likes this.
AZGrizFan is offline
post #15 of 32 (permalink) Old 06-26-2015, 03:02 PM Thread Starter
Motor starting to take shape
Name:	motor on stand 2.jpg
Joe'sToy likes this.
post #16 of 32 (permalink) Old 06-27-2015, 07:17 AM
Indy1K's Avatar
Thanks, I will follow suit. It looks like you placed the center section first as to make sure it is properly aligned.
I have used POR15 many times and love it. What product are you sealing the seams with? Just the POR15 paint?
Good luck with the rebuild. Thanks for the guidance.
Regards,
Kevin
Indy1K
Indy1K is offline
post #17 of 32 (permalink) Old 06-29-2015, 11:00 AM Thread Starter
Regards,
Kevin
Using POR-15 and gonna go over it with some light weight body filler to hide the welds. For the edges at the trunk drop offs I have some 3M brush-able seam sealer.
post #18 of 32 (permalink) Old 08-10-2015, 10:44 AM Thread Starter
Interior work.....
It is premature, but i have started refinishing the seats. I am putting new springs in the front bases and new foam everywhere, so it is best to do it when it is very hot outside....as I am sure you know.
1) I took the seats down to the bare frames and soda blasted them.
2) Installed the new springs in the bases
3) Stretched the new covers on.
4) for the rusty crusty seat tracks, I pulled them off and soaked them in white vinegar for about 3 days. I rinsed them off and they were completely rust free. I painted them and repacked the tracks with grease and they are better than new.
As you can see, I don't have them back together yet, but I wanted to show some progress. The white seat is how they looked before I started. The car had black interior originally that someone did a poor job of recovering in white.
ID:	62602   Click image for larger version
ID:	62610   Click image for larger version
ID:	62618   Click image for larger version
Name:	seat track.png
M1Lover likes this.
post #19 of 32 (permalink) Old 11-03-2015, 11:46 AM
Quoted: 9 Post(s)
Nice job on the seats. They are going to look great. I would have wussed out and just installed some newer GTO seats.
tiretread is offline
post #20 of 32 (permalink) Old 04-10-2016, 09:21 PM
SIK67SS's Avatar
Glad I found this thread- you're making me feel better! I have a $500 66 Lemans getting delivered tomorrow that's also a pull out of the woods. I think only difference is mine has front fenders and a Caddy 500 sitting in the frame rails. Sitting, not bolted lol. Nice progress!
SIK67SS is offline
New to the Crew. 1966 Frame off in progress.... SavetheGoats Member Introductions 0 06-12-2015 12:03 PM
My first build. In progress. Waynes Goat 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 3 08-22-2013 07:07 PM
1966 GTO Build Sheet GTOpat 1964-1974 Tempest, Lemans & GTO General Discussion 3 10-14-2012 10:56 PM
67 GTO Build Thread Chadwa 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 28 11-15-2010 03:55 PM
Progress On My Frame WideTrack 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 5 09-02-2008 07:49 PM
