1966 GTO Frame, floors, inner & outer rockers replaced - Page 2 - Pontiac GTO Forum
 4Likes
post #11 of 15 (permalink) Old 03-01-2018, 10:08 AM
stich's Avatar
Originally Posted by M1Lover View Post
REAL good job on your project Jeff. You're making great progress.
I've got a '66 GTO that has the windshield, dash and back window rust common to so many of these cars from back east. I found a donor '66 LeMans here in Arizona and first thing, popped off the trim around the windshield and back window. Full of dirt, but dry as a bone. My challenge is to take the two bodies and make one good one. Going to break the big project down into several smaller ones. I'll start with getting the GTO body off of the frame. Local powder coating shop will sandblast and powder coat the frame for $500. Starting with that solid foundation should motivate me to get the body put on with new mounts and begin the body project.
Thanks for the inspiration and Butthead quote. Now, I'LL be repeating it over and over in my head! LOL.
Hunter
Hey Hunter, I've also replaced my frame and need some original, if possible, body parts for the rest of my project. mines a convertible but what I need is interchangable. Need full rockers, inner and outer, and the lower areas of the rear wheel wells (below the trunk floor line) on both sides if thats even possible. Please keep me in mind if you have left over body parts on your doner car
stich is online now
post #12 of 15 (permalink) Old 03-01-2018, 10:15 AM
stich's Avatar
Originally Posted by jeff613 View Post
Thank you Cafr119 & M1Lover.
Hey Hunter that's great that you have donor car and will be able to make a complete solid car from the two of them!
Once you get that frame back from powder coat you will be surprised how much that motivates you to get to work!
Heck, I fell in love with my new frame! lol
I would smile each time I looked at it and think to myself how much nicer my Goat was going to be after all the work.
My old frame was a lot worse than I first thought. I was embarrassed that I had been driving on it all of these years.
I'm glad I finally got serious with the car and started the ton of work that it took.
Good luck with your project, pace yourself and don't get overwhelmed! It will be well worth it when Your finished
Jeff I'd be real interested on any advice to replacing rockers. I'll need to do that also. I've got a new frame also and am working on all new suspension. plumbing, exhaust and new 455/ 4 spd. conversion on it right now. I do have access to a body rotisserie when I get to that part so that will make thing easier. Thanks for your input/advice.
stich is online now
post #13 of 15 (permalink) Old 03-02-2018, 10:43 PM
Quoted: 11 Post(s)
Jeff,
Who's Floor pan sections did you use and are some manufactures rocker better detailed than others?
Sixty7GTO is offline
post #14 of 15 (permalink) Old 03-23-2018, 07:43 AM Thread Starter
jeff613's Avatar
Sixty7GTO
I believe the floor pans were Goodmark. A lot of the rocker panels are stamped without the sharp bends like original. I did find a few that say they are original style and they are priced fairly high. Do a search for original replacement rockers and you can find them.
jeff613 is offline
post #15 of 15 (permalink) Old 03-23-2018, 07:55 AM Thread Starter
jeff613's Avatar
Stich
If you are just replacing the outer rocker panels it's not very difficult. You need to pop the spot welds at the floor pan and at the bottom lip and do a little cutting and grinding to remove the excess metal. Inner rockers are about the same procedure. I used a cut off tool and cut the panel just to where the upper and lower lips are for the spot welds and then popped the spot welds and removed the excess metal.
Hope that helps you out.
jeff613 is offline
My first frame off 1966 GTO chevyboy91188 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 92 04-21-2016 07:33 AM
My 1966 GTO frame off project 1966 GTO 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 13 12-02-2010 11:42 AM
taking the frame off and fixing the floors helpful hints? chevyboy91188 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 15 01-06-2010 11:52 AM
