1966 GTO Sport Coupe Resurrection - Pontiac GTO Forum
post #1 of 17 (permalink) Old 11-21-2011, 11:46 AM Thread Starter
RustWrangler's Avatar
Hey Guys,
I finally after looking and looking found a GTO that I thought at the time was a good deal. upon better inspection now I have it home Have found LOTS of rust after a few stiff drinks and hanging my head kicking the dirt awhile I have mustered up the faith to say I can fix IT! First time ever attempting a project of this magnitude but I have been drawing from some of the other guys threads like TMP and Thumpin and a bunch of others and I have to say thanks for the inspriation.
I will start an actual build thread when I get going (I'm waiting on my workshop to be built ) but it looks body wise everything from the fender well up is solid, everything below is crap... so new rear quarters, trunk pan, floor pan, possible tail pan (I might be able to save the original) possible inner and outer fender wells basically the whole rear bottom half of the car lol
But here she is now in all her glory I look forward to getting started and hope I can do as well as a lot of you have done!
RustWrangler is offline
post #2 of 17 (permalink) Old 11-21-2011, 12:55 PM
Looks good to me! you're gonna need a welder, some tools, and a lot of Jim Beam .....Eric
ID:	13033   Click image for larger version
ID:	13034   Click image for larger version
Eric Animal is offline
post #3 of 17 (permalink) Old 11-21-2011, 02:13 PM Thread Starter
Thanks Eric, yea the pictures are a little decieving she's rough but i'll get her straightened out.
speaking of welders yes I need one, I was looking at the Eastwood mig 135 or 175 to use anyone have any thoughts or recommendations?
I have never welded anything before and it will only probably ever be used for autobody repair. I know from what I have read that I should get one that I can use the gas(argon) with.
other things I know I will need to invest in include a new Compressor thinking something that can push 15cfm at 90psi should do the trick. A sandblaster, and a good paint gun. cheap recommendations on any of those would help also. any other specialty equipment you guys think will help? I have most of the common tools, cut off wheels, DA, etc...
Thanks!
post #4 of 17 (permalink) Old 11-21-2011, 05:03 PM
Quoted: 23 Post(s)
ahhh another 66' post car....roll up your sleeves and dive in. i had not wrenched on my own cars in 20 years before last september when i got the Tempest in all her glory. I was lucky to find an original bodied car that needed no welding, so i got off easy there. Original plan was to job the body and paint out until i saw a few estimates. Ended up doing everything myself over a 10 month span, so "you can do it", and this is the best place to gather information from. My photobucket shows the process from start to end. Best tool i got from Harbor freight was a set of jack up wheel casters, allowed me to move the car in tight spaces without starting it and by myself. They have sandblaster and HVLP gun for primer if your just planning on using them for the project and not on a daily basis. Just give a shout if you have any questions, glad to help, and welcome to the reservation Rust....
1966 Tempest pictures by instg8ter - Photobucket
Brian
Instg8ter is offline
post #5 of 17 (permalink) Old 11-24-2011, 09:17 AM Thread Starter
Thanks Brian,
yea I had been tagging along with your project for awhile to, that's a beautiful tempest you have! I'll Definitely be asking a few questions when I get rolling on mine
does anyone know if there's any kind of shop manual or disassemble handbook that describes how to properly disassemble the car (such as window trim, moldings, windows, etc..)
Thanks,
Rod
post #6 of 17 (permalink) Old 11-24-2011, 09:53 AM
Quoted: 23 Post(s)
Fisher Body manual, and GTO restoration guide check amazon.com...
Rust, your camera will be your best friend so keep it charged and close. during dis-assembly keep a photo log from every angle so when you go to reassemble you can see what the installed piece looks like installed correctly. Bag and tag every part of the assembly together then in a bin in sub assemblies (Interior, front suspension...etc.). Start a photobucket or other archive so if your card goes bad, harddrive whacks out to have them backed up, remember a pictures worth a thousand words. The other nice thing is your resto will be archived to go along with the car. The one thing i wish i would have done is mount a camera on the wall and mark the tires on the floor and taken shots from the exact same angle of every phase, would have made a kickass slideshow.... (just throwin it out there would love to see it done.)
post #7 of 17 (permalink) Old 11-24-2011, 10:45 AM
Rusty, Eastwood stuff is pretty good. you don't need a lot of welder to fix body panels. You should consider a torch also , for straightening and shrinking/stretching panels. Contact Randy (05 GTO) he has 2 66 Gtos that he restored, he also lives in Georgia. He is full of.....good info! Happy Thanksgiving, Eric
P.S. Brian just went down the same road you are going....
post #8 of 17 (permalink) Old 11-27-2011, 10:46 AM Thread Starter
Thanks guys! all good advice, I am settling in for a long haul on it so I want to take my time and do it right. I've got a 67 Chevy stepside truck I am going to run through quickly first just to get some practice on the welding, bodywork, etc... so when I start cutting and welding on this one I'll have a little bit of experience, that's the plan anyway lol....
Right now I'm thinking about the best way to Preserve the GTO in its current state until I can really get started on it, I have been sanding all the surface rust off and spraying it with rustoleom rust reformer and primer. I'm thinking I need to pull the interior out and hit everything I can see or reach with some POR15 when I am done with the exterior. or am I just being overly cautious and should save the work and just leave it be for now until I am ready to work on it?
Is it worth the work to try and preserve it or will it not really get any worse in the next year or two?
Brian, I'll have to see if i can set my shop and camera up like that for a start to finish slide show that would be pretty cool!
Eric, thanks, I hadn't really thought of a torch looks like another one for the Christmas list!
Hope yall had a great Thanksgiving!
Rod
post #9 of 17 (permalink) Old 11-27-2011, 10:57 AM
Quoted: 100 Post(s)
Wrangler, you're doing the right thing, IMO. Rust NEVER sleeps. A few bucks and hours now may save you many in two-three years when entire sections need to be replaced (if the car isn't inside, that is). I remember a friend of mine opening up the trunk of his rarely-optioned '65 GTO that he had stored outside (but in dry central CA), and he was shocked when we were looking at our feet through the big hole that used to be the trunk!! Good luck on your project, coupes are not really common, but make great drivers with very few rattles and squeaks!!
post #10 of 17 (permalink) Old 12-01-2011, 12:58 PM
FlambeauHO's Avatar
Quoted: 8 Post(s)
That looks like a lot of fun! As for welders, I had really good luck with the Lincoln Welder from Home depot, think it was the weld pak 140? or 120? Anyway, worked great until it was stolen from my old shop in Abilene TX. I now have a century inverter arc and a 220 wire feed with no 220 in the garage. Guess i'll be welding in the laundry room haha
Good luck and keep us posted!
FlambeauHO is offline
Post to sport coupe conversion? PontiacDave 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 10-22-2009 09:30 PM
Difference between Sport Coupe/Hardtop 67 mshidner 1964-1974 Tempest, Lemans & GTO General Discussion 9 04-12-2009 10:18 PM
Holden Coupe 60: Blueprint for a new GTO. Or G8 Coupe. Or even a Firebird 05GTO In the News 19 06-11-2008 05:01 PM
GTO or G35 Coupe ??? Tim Currie 2004-2006 GTO General Discussion 82 12-02-2006 09:05 AM
