1967 GTO horn pair physical location - Pontiac GTO Forum
post #1 of 10 (permalink) Old 03-13-2012, 12:35 PM Thread Starter
Where SHOULD the pair of original 1967 Pontiac GTO horns be physically located within the engine compartment? I am looking to purchase a new pair of horns (original style horn kit pair, including universal mounting brackets and hardware) from Ames Performance Engineering (item M230 on page 160 of their 2011 catalog), but I am not sure exactly where they should be mounted within the engine compartment. Any help would be GREATLY appreciated!!! Thanks!
jbach is offline
post #2 of 10 (permalink) Old 03-13-2012, 12:50 PM
On the center vertical brace between the radiator and the header panel,
05GTO is offline
post #3 of 10 (permalink) Old 03-13-2012, 12:56 PM Thread Starter
Thank you very much, 05GTO!!! Could you possibly suggest a good diagram I can reference, or photos? I still have not received my shop manuals.
Thanks,
Jim
jbach is offline
post #4 of 10 (permalink) Old 03-15-2012, 05:32 PM
Jim, They go here......they use bolts that thread into the holes, and I THINK they have little "guide tabs" to position them correctly.....Eric
Eric Animal is offline
post #5 of 10 (permalink) Old 03-18-2012, 01:44 AM
kjk990's Avatar
Here is a picture of them installed. I hope this helps.
Name:	front end .jpg
kjk990 is offline
post #6 of 10 (permalink) Old 03-21-2012, 01:12 PM Thread Starter
Many thanks to all of you for your help!!!
Jim
jbach is offline
post #7 of 10 (permalink) Old 07-05-2012, 11:08 PM
Neither of my factory horns make a sound, but when I press the steering wheel buttons, I get a click. To me, that means the problem lies between the relay and the horns themself. My front end looks to be original, like it's never been apart. It's extremely tight in there, is there a 'good' way to access the horns. I've got small hands, but do I still have to pull half the front end off? Thanks!!!
mysweet67 is offline
post #8 of 10 (permalink) Old 07-09-2012, 07:35 PM
FYI universal mounting brackets will not fit correctly on the 67, so horns will not be positioned at the right angles. horns come out below the bumper, but no need since wires are at the top of core support.
pontiac is offline
post #9 of 10 (permalink) Old 05-21-2015, 10:36 AM
GTO horn
Is the horn relay around the horns or back by the firewall?
barscgrs is offline
post #10 of 10 (permalink) Old 05-21-2015, 10:51 AM
Quoted: 106 Post(s)
No, you can remove them from the bottom without disassembling anything.
Once you have them out you can test them with jumpers off of the battery.
There is also a screw to adjust the tone.
Mine were not very loud but after cleaning and adjusting they now emit a pretty good blast.
Goat Roper is offline
1968 GTO Horn Relay Location Red1968 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 04-13-2011 10:02 PM
Location of the horn relay Stickyfingersfrank 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 02-24-2011 08:19 AM
1972 GTO Horn Relay location??? 1972goat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 02-02-2011 08:53 AM
65 GTO Horn location? Chris Holabaugh 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 03-21-2009 10:47 AM
A pair of Mustangs fergyflyer Racing and Kill Forum 5 08-30-2006 01:43 PM
