1967 GTO restoration journey - Pontiac GTO Forum
post #1 of 16 (permalink) Old 09-04-2017, 08:59 PM Thread Starter
Since bringing home our 67 gto, I've been tinkering/working on it when I can. Thought I'd give a few updates along the way.
Built a cart for the body that is very similar to the design from Squidtone (thanks again Dave!). Body was removed from the frame and set on the cart with help from some friends and neighbors.
The frame is actually pretty solid, which surprised me considering the condition of the floor and trunk. After some measurements, the frame appears to be pretty straight with no major issues noted. There will be some welding needed around some of the body mounts, to make the holes clean again - but nothing too bad. Numbers were found on the frame, after wire brushing and cleaning, matching the frame to the car.
ID:	96274   Click image for larger version
ID:	96282   Click image for larger version
ID:	96290   Click image for larger version
DMH22 is offline
post #2 of 16 (permalink) Old 09-04-2017, 09:13 PM Thread Starter
An AMD one piece floor pan was bought. This pan has the inner rockers and braces already attached.
May be overkill, but some bracing was added to help keep everything in place before cutting the floor out.
Side note, Ive been keeping an eye out for some NOS parts and although I don't need it right now, I found a great NOS tail panel. GM sticker was still on it and is in great shape. I will need this down the road and couldn't pass up a great piece at a great price.
ID:	96306   Click image for larger version
ID:	96314   Click image for larger version
ID:	96322   Click image for larger version
ID:	96330   Click image for larger version
DMH22 is offline
post #3 of 16 (permalink) Old 09-04-2017, 09:20 PM Thread Starter
Lots of spot welds removed and more trimming/cleaning done - prepping for the new pan. Portions of the outer rockers will need to be replaced, but that will be done later on. The body will eventually be chemically stripped and cleaned, once the car is a little more solid.
ID:	96346   Click image for larger version
ID:	96354   Click image for larger version
ID:	96362   Click image for larger version
DMH22 is offline
post #4 of 16 (permalink) Old 09-04-2017, 09:24 PM Thread Starter
During some of the spot weld removal, my single stage sanborn compressor quit on me. I suppose it was a good excuse to upgrade to a 2 stage unit. Found this Dewalt compressor after doing a lot of research and checking reviews, was a good deal and (other than being very yellow) its doing a great job - much more power and even a little quieter.
DMH22 is offline
post #5 of 16 (permalink) Old 09-04-2017, 09:35 PM Thread Starter
New pan was fit into place - after some aligning, a few plug welds were placed. Once the trunk pan is finished, the body will be set back onto the frame to confirm placement, then everything will be welded completely. Overall, this pan fit very well.
ID:	96402   Click image for larger version
ID:	96410   Click image for larger version
ID:	96418   Click image for larger version
ID:	96426   Click image for larger version
DMH22 is offline
post #6 of 16 (permalink) Old 09-04-2017, 09:37 PM Thread Starter
Here is one more of the floor pan, installed.
DMH22 is offline
post #7 of 16 (permalink) Old 09-05-2017, 12:04 PM
64GTOConvertible's Avatar
Quoted: 17 Post(s)
Awesome work!
64GTOConvertible is offline
post #8 of 16 (permalink) Old 09-05-2017, 05:09 PM
Quoted: 78 Post(s)
Looks great! I noticed your car doesn't have the diagonal braces for the rear suspension connecting the lower control arm to the cross member. I wonder when Pontiac started using those braces?
Sent from my XT1585 using Tapatalk
Shake-N-Bake is offline
post #9 of 16 (permalink) Old 09-05-2017, 05:52 PM
Quoted: 347 Post(s)
If I am correct, and as I recall, the upper/lower control arm braces were used on manual trans cars and not automatics. If this one is an automatic, then that would explain it. However, as you questioned, they may not have been installed in the beginning of the '67 run and were installed some time later after production began.
Other good questions would be if the 3-speed manual transmission cars got these, did all 4-speed cars, regardless of rear axle gearing, get them or only the 3.90/4.33 geared cars, and how about any Ram Air automatics?
post #10 of 16 (permalink) Old 09-05-2017, 06:00 PM
Quoted: 347 Post(s)
Originally Posted by 64GTOConvertible View Post
Awesome work!
X2 on Awesome! Great work as well as the detailed pictures. Other members have asked about the bracing of the body when doing the major work you are, so great pics for all to see.
You are making it look soooooooo simple (like one of the TV/cable network shows- what did it take you, a day to skin and spot weld the floor in, and look no dirt on the garage floor either ), yet I know it ain't so. Keep up with this thread, and keep the pictures coming. If you run into snags, post them along with what you did as my experience is that no project ever goes smooth and there is more than one monkey wrench being thrown into the project.
four questions about a 1967 GTO under restoration alanmay0 1964-1974 Tempest, Lemans & GTO General Discussion 11 09-02-2017 05:36 AM
69 gto restoration 1969 gto 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 8 01-01-2015 03:53 PM
70' Gto Restoration - Need Help TreySmith 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 25 07-16-2009 11:34 AM
Restoration of 69 GTO TomGoat 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 3 03-20-2008 07:03 PM
Project: 1967 GTO Mechanical Restoration opelspyder 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 17 08-27-2007 11:26 AM
