1967 GTO Rust problem - Pontiac GTO Forum
post #1 of 4 (permalink) Old 10-18-2012, 09:15 PM Thread Starter
New to Forum. Just bought a 67 GTO hard top and going to do a frame off
restoration. Car has some rust but floors and trunk are solid. It does have a problem with the body side of the rear frame mounts behind the rear inner finder wells. The frame side is good but the body side is rusted badly where bushing would bolt to. Anybody have an idea where I might find these body parts or will I have to get something fabricated? I am not sure even what this area of body is called. Thanks for your help!
dayjt is offline
post #2 of 4 (permalink) Old 10-18-2012, 09:24 PM
I believe you are talking about the trunk body brace, see if this is the part;
1964-1967 GTO - Body Braces | OPGI.com
05GTO is offline
post #3 of 4 (permalink) Old 10-19-2012, 09:23 AM
jmt455's Avatar
You can also get those parts from AMES Performance, Year One, Performance Years, Rock Auto (yes, really!) and most big auto parts chains.
If that area is bad, you might find that other body mount areas need repair, too.
1968 Pontiac GTO
2008 Pontiac G8 base
jmt455 is offline
post #4 of 4 (permalink) Old 10-20-2012, 06:29 AM
Joe'sToy's Avatar
I had the same problem, this summer when I changed my original body mounts on my '65. The rear trunk cross brace was rotted on the drivers side. I had a local shop make a piece and weld it in, worked like a charm, now with all new mounts she rides like a brand new car. The shop only fabbed up a "U" channel that they welded into the trunk floor, that matched the existing brace. Cost was like $80.00 for material and labor.
Joe'sToy is offline
65 GTO with a little bit of rust. Thumpin455 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 318 01-10-2014 09:29 PM
zero rust vs rust encapsulator tspring 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 3 09-11-2011 06:07 PM
What to do with this rust? BatmanGTO 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 26 08-16-2011 08:09 AM
1967 GTO Idle problem BigDuke0767 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 03-08-2011 08:11 PM
rust out, help! danthepontiacman 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 03-27-2009 08:11 AM
