1967 lemans body work - Pontiac GTO Forum
post #1 of 5 (permalink) Old 01-01-2011, 04:40 PM Thread Starter
LAZ
i wanted to sandbalst the body at 1st but i decided to use a 6" da using 80 Grit sandpaper man on man idi it take me a long time to sand it down to the original paint it took me 4hr and all i did was the right side quarter panel is their a better way or am i doing it all wrong i start with 80 and end with 150 grit
ID:	9876   Click image for larger version
1967 LEMANS
LAZ is offline
post #2 of 5 (permalink) Old 01-01-2011, 10:06 PM
Thor7352's Avatar
LAZ,
Try 'turning off' the dual action part of your DA. Make it so that it only spins and you will cut through the paint a lot quick but be carefulnot to get carried away and cut too much metal. That may help speed things up. Looks like a nice project!
-Thor
Thor7352 is offline
post #3 of 5 (permalink) Old 01-02-2011, 10:55 AM
i scrape the paint off with a sharp blade before i da it. speeds it up a lot.
freethinker is offline
post #4 of 5 (permalink) Old 01-02-2011, 01:37 PM
66tempestGT's Avatar
if it was easy women and children would be doing it!
Shane Doss
66 tempest
64 el camino
02 mullis dragster
66tempestGT is offline
post #5 of 5 (permalink) Old 01-02-2011, 08:19 PM Thread Starter
LAZ
Originally Posted by Thor7352 View Post
LAZ,
-Thor
i will try that thanks........
1967 LEMANS
LAZ is offline
starting body work Instg8ter 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 34 01-14-2011 08:59 PM
where to get body work/paint in michigan hurleymotoxer118 Exterior Discussions 0 07-17-2007 02:38 PM
Body Work DallasSleeper Exterior Discussions 11 02-14-2006 12:46 PM
Need body work advice Legionaire Service, Maintenance and Technical Discussion 0 02-08-2005 07:00 PM
