1967 Lemans fuel sending unit - Pontiac GTO Forum
post #1 of 5 (permalink) Old 01-05-2012, 05:51 AM Thread Starter
Hi Everyone!
I have a 1967 lemans 326, 2bbl non air convertible.
I'm in the process of replacing my fuel tank and sending unit. I was looking at the old sending unit currently on the car and i see that it's the type with a 3/8 gas line & a 1/4 inch return line. The 1/4 inch line is plugged (not connected to anything). I believe the tank was replaced years ago with a tank from a GTO that's why it has the 1/4 return line.
I'm thinking of installing a new fuel sending unit with just the 3/8 outlet. Does anyone have any thoughts on this? If i install a new sending unit with a 1/4 inch return can i just plugg it with a rubber cap?
Thanks,
DennyOH is offline
post #2 of 5 (permalink) Old 01-05-2012, 05:10 PM
either way is fine.
pontiac is offline
post #3 of 5 (permalink) Old 01-05-2012, 07:58 PM
The 1/4" return line was used to return vapors to the gas tank on cars that had A/C. If you use the return line I believe you will need a fuel pump that has two hose connections as well. I would get a sending unit with only the 3/8 connection.
JMHO
05GTO is online now
post #4 of 5 (permalink) Old 01-05-2012, 09:26 PM
jetstang's Avatar
Adding the return line will also stop vapor lock on hot days, it's a nice upgrade if you already have the sending unit.
Burning rubber since 1982!!
jetstang is offline
post #5 of 5 (permalink) Old 01-09-2012, 02:09 PM
xconcepts's Avatar
Excuse me for jumping in on this thread, but I finally was able to drop my tank and replace the sending unit. Holy crap was the sock done. Completly black and could almost crumble away by touching it.
xconcepts is offline
Fuel Sending Unit: with or with out vent yousaygo 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 04-27-2010 07:58 AM
fuel sending unit question? 67 Lemans John 1964-1974 Tempest, Lemans & GTO General Discussion 1 11-16-2009 07:29 AM
A.C. car fuel sending unit asshauler 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 04-23-2008 12:07 PM
What is the differance fuel sending unit 67 Lemans John 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 03-22-2008 03:49 PM
Question: Fuel sending unit 1967 67 Lemans John 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 03-18-2008 07:27 AM
