1967 Tempest Rat Rod - Pontiac GTO Forum
post #1 of 23 (permalink) Old 08-05-2015, 12:44 PM Thread Starter
oramac7691's Avatar
Well Iím starting work on my 67 Tempest ĎĎRat RodĒ project.
A buddy of mine found the car in a junkyard in the south while he was looking for pars for his GTO. Thea car was a bit too nice to use as a parts car so he kept it. A few years down the road he needed to sell All of his car so I picked up the GTO and the Tempest along with a couple LS motors from him.
So I decided to work on the white Tempest first. Itís not a GTO and the Body was rust free it had a nice patina to it so we thought we would leave it ratty replace the locked up OHC6 with an nice fuel injected LS motor, and do a frame off with some brakes and upgrades.
ID:	62194   Click image for larger version
ID:	62202   Click image for larger version
ID:	62210   Click image for larger version
ID:	62218   Click image for larger version
oramac7691 is offline
post #2 of 23 (permalink) Old 08-05-2015, 06:25 PM
Quoted: 365 Post(s)
More of a sleeper project aka rat rod theme. I would leave the body alone, maybe add "Lot #" to those numbers on the doors so it looks like it came right out of Pull-A-Part. Put a protective coat over the body -rust and all (I don't know if POR-15 might work in "clear" and spray it on?). Rebuild/upgrade the chassis and I think I'd go with a blanket/afghan over the front bench seat, no new interior stuff. I could live with an LS swap in this instance.
post #3 of 23 (permalink) Old 08-07-2015, 08:42 AM Thread Starter
oramac7691's Avatar
Thanks Jim
Thatís exactly it I was planning on leaving the surface rust on the body, but was not sure if I wanted to clear over it or just leave it. If I clear it should I use high gloss or a matte clear?
We just pulled off the body from the frame and blasted it and getting ready for some mini tub action. And the normal new bushing, springs, disk brake exc. Then I will spray it all with a nice coat of flat black.
I just welded in some floor pans and painted the floors and entire underbody with some nice flat black truck bed liner.
I think Iím going to run the factory original vinyl flooring back in it cleaned up very nice.
My next question was to recover the seat or toss a blanket over it but you already answered that.
ID:	62338   Click image for larger version
ID:	62346   Click image for larger version
ID:	62354   Click image for larger version
ID:	62362   Click image for larger version
post #4 of 23 (permalink) Old 08-07-2015, 07:40 PM
Quoted: 365 Post(s)
Originally Posted by oramac7691 View Post
Thanks Jim
Very cool. I would probably go with a matte overcoat to go with the aged look. I think gloss would be out of place, especially on those rusty spots. I would try a spot and see how it looks. You can email the POR-15 guys and ask them what might be best. I have seen rat rods that have some bare steel/rust as their exterior look and they have some kind of coating/clear that keeps them that way without further rusting. There may be another type coating they use, but I think POR may work.
I am doing my frame using the POR-15 Rust Preventative stuff after I sandblasted the loose rust/road dirt off. My frame is pretty good and I did not go crazy on it, just like I said, went over it to simply clean it off leaving light surface rust in areas that I only dusted over with the sand blaster. The POR-15 seems to work best on rust surfaces/sand blasted surfaces, so I left it at that and brushed on a light overcoat. Says to use 2 coats, but, I feel one coat is enough as I didn't have any heavy, deep, flaky rust at all. 2 coats probably ensures you "bury" the rusty stuff and seals it in. I just purchased a pint of POR-15 Top Coat as this is supposed to go right over the Rust Preventative coating and further protect and seal it. You can paint, but it seems in my research that some paints take to it and some may cause you more grief and need to be re-done. So I bit the bullet and thought I would try it this weekend and see if it works.
Of course there are indeed other options, and cheaper too, but I wanted something that "claimed" to encapsulate the rust and seal it. I like Rustoleum primer, but these new paints have been reformulated and just don't apply like they used to and lift/craze when you re-coat if you are looking for a smooth job, so I am leery if the protect as they used to.
The quart of POR-15 covers a lot. You pour what you need into another container. I think I poured out about 1/2 the can and used about 1/4 of that to coat the rear section of my frame which begins going up over the wheels and on back. If I did a 2nd coat, 1/2 can would be about right. So my guess would be that you would need just at 3 quarts to do a frame 2 coats with a brush. Might be some good stuff to brush into your lower inside doors and quarter panels. Just follow directions. As hot as it is lately, I waited until late afternoon for the temps to drop a bit before painting as it says not to paint above a certain temp. First time I have ever used the stuff, so this is not an endorsement as I don't know how good it really is or if it works like it claims. Stop Rust with POR-15ģ - We Know What Permanent Means! Ordered mine from Summit online.
PS How about adding just 1 electric exhaust cut-out so you could just tweak it open enough to make the car sound like it has an exhaust leak. Talk about suckering some "new muscle car" owner in and putting him/her to shame with that old rat bag of a car!
post #5 of 23 (permalink) Old 08-24-2015, 08:46 AM Thread Starter
oramac7691's Avatar
I just got the frame all painted. love the look of new paint
ID:	63273   Click image for larger version
ID:	63281   Click image for larger version
ID:	63289   Click image for larger version
post #6 of 23 (permalink) Old 08-24-2015, 09:41 AM
Quoted: 100 Post(s)
Back in the day, before the term Rat Rod, the term for a tired old worn out car was 'roach', at least here on the Left Coast. Remember though, that was an era of Peace, Pot, and Microdot! Neat project you have, I like the idea, and keep us updated!
post #7 of 23 (permalink) Old 09-08-2015, 11:39 AM Thread Starter
oramac7691's Avatar
Well we got the flat black on the frame and did not like how it collected watermarks so we scuffed it up and spray it with gloss black and it looks much better. Then we starts suspension assembly and the disk brake conversion kit. Itís all coming together.
ID:	64113   Click image for larger version
ID:	64121   Click image for larger version
ID:	64129   Click image for larger version
ID:	64137   Click image for larger version
post #8 of 23 (permalink) Old 09-08-2015, 11:49 AM Thread Starter
oramac7691's Avatar
After a few cocktails we decided to do a bit of work on the rear end. Well we did not make much progress. But any time in the shop with your old lady is good.
post #9 of 23 (permalink) Old 09-08-2015, 08:42 PM
Quoted: 365 Post(s)
Ain't no way. That's gotta be some gal from a modelling agency you had to pay to look like she was enjoying herself. Ain't no way. OH! I just got it. You said "do a bit of work on the rear end."
post #10 of 23 (permalink) Old 09-16-2015, 01:21 PM Thread Starter
oramac7691's Avatar
Making some progress. We have all the floors welded in and painted flat back inside and out as well as the trunk pan. Then we started sliding the frame back under the old beast I picked up some rolling dollies from harbor fright that made the job a lot faster. Im starting to run the brake lines now and getting ready to assemble the suspension and paint the inner fenders. And with my extra money this week I hired the girl from the modeling agency to help out.
ID:	65177   Click image for larger version
ID:	65185   Click image for larger version
ID:	65193   Click image for larger version
ID:	65201   Click image for larger version
1967 Tempest Search CHIEF73 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 01-29-2015 08:10 PM
Hot Rod Garage 64 Tempest Suspension Overhaul Orion88 1964-1974 Tempest, Lemans & GTO General Discussion 0 10-05-2014 07:31 PM
1967 Tempest Build Pontiac_Madness 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 28 05-29-2013 09:18 AM
Color question for 1967 Tempest jday240 1964-1974 Tempest, Lemans & GTO General Discussion 5 07-09-2012 09:12 AM
