1968 exhaust manifold bolts - Pontiac GTO Forum
post #1 of 5 (permalink) Old 04-30-2011, 12:22 AM Thread Starter
I have a 68 GTO with a stock 400 350 hp engine and it appears there are only 4 exhaust manifold bolts per side.The exhaust manifolds are drilled for 6 per side.I want to replace the exhaust manifold to cylinder head gaskets and am curious on the amount of bolts thanks
izzy412 is offline
post #2 of 5 (permalink) Old 04-30-2011, 10:54 AM
Quoted: 100 Post(s)
If it is the stock, non HO manifolds, then there are 6 bolts per side. Be careful on the torque. The HO manifolds use less, due to the casting thickness and size. Later cylinder heads that did not come on these cars originally are sometimes not drilled or equipped for the outside bolts to hold the manifolds on. Not an issue, since the manifolds are rigid and tend not to leak. Tubing headers will need all 6 bolt holes. What is the number cast on to the center exhaust port of the heads?
post #3 of 5 (permalink) Old 04-30-2011, 12:15 PM Thread Starter
It has the number 16 cast into the center exhaust port
izzy412 is offline
post #4 of 5 (permalink) Old 04-30-2011, 05:33 PM
Quoted: 100 Post(s)
#16 heads are normally drilled and tapped at all 6 holes. No worries.
post #5 of 5 (permalink) Old 04-30-2011, 11:15 PM
when engine is cold, put a bolt in there and see if there is a tapped hole.
pontiac is offline
Exhaust Manifold Krets 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 12 02-28-2016 12:36 AM
exhaust manifold Topkat 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 4 01-14-2011 10:30 PM
manifold bolts 68gtohawk8369 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 04-19-2010 07:53 AM
ft. Lb. torque for intake manifold bolts marks64 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 07-02-2009 10:55 AM
exhaust manifold bolts izzy412 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 1 05-07-2009 07:45 AM
