1968 gto - Pontiac GTO Forum
post #1 of 4 (permalink) Old 05-01-2017, 10:14 PM Thread Starter
Quoted: 31 Post(s)
1968 gto
Need help on figuring out a problem. I have a 68 gto that has a real bad vibration at any speed . When I put the car in neutral and just roll it goes away. Does this tell me it's the transmission , torque converter or engine and mounts and rules out drive shaft , rear end and all other suspension parts and wheels? This is a 400 freshly rebuilt with a turbo 400 that was rebuilt. Motor dyno good And tuned well. It's a stock rebuild. Thanks for any help. I am close but this vibration has got me. HELP Doug
dd68gto is offline
post #2 of 4 (permalink) Old 05-02-2017, 05:12 PM Thread Starter
Quoted: 31 Post(s)
Any thought? I hope I did not make this confusing. I think that it goes away when rolling in neutral it rules out drive shaft,rearend and suspension/wheels. Am I right? Any way of ruling out more parts? Doug
dd68gto is offline
post #3 of 4 (permalink) Old 05-03-2017, 08:58 PM Thread Starter
Quoted: 31 Post(s)
Thanks for help GTO forum . Got my help in another forum and can't mention them or I will get banned . Best luck to all. Doug
dd68gto is offline
post #4 of 4 (permalink) Old 05-04-2017, 03:47 PM
1968gto421's Avatar
Quoted: 72 Post(s)
I haven't been banned (for posting links to other forums) but I saw where you probably used the PY forum which many of us here also use. I think many members here only check the forum irregularly or on weekends. Had some of the knowledgeable guys here seen your thread i know they would have jumped in...don't give up on us yet, Thanks! (Glad you got the help you needed.)
1968 GTO bad vibration - PY Online Forums
Another forum that is good (since a GM A-body is a GM A-body) is the Chevelle forum:
http://www.chevelles.com/forums/#general-tech-area
I discovered that alot of the GTO forum members and also the PY forum members also use the Chevelle forum forum as do I.
Best of Luck with your "68! I also have one and coincidentally my TH400 also "slams" when put in D or R. I'm gonna change timing and idle speed before I look at the TH400 but your answers on the PY forum are interesting. Let me know what the final solution to your GTO's problem is...Thanks!
1968gto421 is offline
1968 GTO Value tgilh01 Member Introductions 2 04-08-2016 09:02 PM
My (new) 1968 GTO Mikesan 1964-1974 Tempest, Lemans & GTO General Discussion 4 10-20-2014 10:04 AM
1968 gto Goat68 Member Introductions 2 12-18-2013 07:12 PM
will a 1968 lemans floor shifter cable work on a 1968 GTO dual gate shifter par4n1 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 03-09-2013 08:50 PM
looking at 1968 gto huggytree 1964-1974 Tempest, Lemans & GTO General Discussion 4 09-11-2009 05:50 AM
