1968 GTO Fuel lines and Returns - Pontiac GTO Forum
post #1 of 5 (permalink) Old 01-25-2017, 10:33 AM Thread Starter
Hi guys I'm in the process of restoring my 68 GTO and I'm confused as to what side the fuel lines in on and what side the return is on. Also are their two returns?
The reason I ask is I have what looks like a fuel line on the passenger side that ends right by the tank and two lines on the driver side which are definitely fuel lines/return. One is larger than the other on the driver side.
Any help is greatly appreciated!
Thanks!
Pstamato is offline
post #2 of 5 (permalink) Old 01-25-2017, 10:35 PM
Quoted: 11 Post(s)
The fuel line(s) should be on the driver's side, I believe the return line was used on cars with a/c.
05GTO is online now
post #3 of 5 (permalink) Old 01-29-2017, 08:54 PM Thread Starter
Where did the return line connect engine side?
Fuel pump? Carb?
Pstamato is offline
post #4 of 5 (permalink) Old 01-30-2017, 04:17 PM
On my 69 GTO.
Drivers side has 3 lines.
1 brake
2 fuel.
the fuel lines pass though the frame and come out of the frame on the engine compartment side. both go into the fuel pump.
FooGee is offline
post #5 of 5 (permalink) Old 01-30-2017, 07:04 PM
Quoted: 402 Post(s)
If you do a search through the forums, this has been covered. I believe it was for a 1967 GTO, which is different year, but might give you some info. The air-conditioned cars had the extra 1/4" return line and as I recall it came off the fuel filter at the carb.
67 gto fuel pump,lines, starter questions 42willys 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 16 04-14-2015 04:05 PM
2005 Pontiac gto fuel tank lines Jesse6.0 2004-2006 GTO General Discussion 6 01-17-2013 01:26 AM
67 GTO Fuel lines lam63 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 10-18-2011 08:27 AM
72 GTO fuel and brake lines johnny60 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 1 06-07-2011 12:28 AM
69 GTO fuel and vacuum lines jerry300ex 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 05-05-2008 08:22 PM
