1968 GTO Hideway Headlight Doors - Pontiac GTO Forum
post #1 of 7 (permalink) Old 03-11-2019, 06:57 PM Thread Starter
Big Dave's Avatar
I a newbie here having joined today. I have a 1968 GTO with hide way headlights and discovered that the headlight doors will not stay closed with engine is turned off. I've checked the headlight switch with vacuum gauge as well as the vacuum hoses. The system checks out so what am I missing. Any suggestions will be greatly appreciated.
Big Dave is offline
post #2 of 7 (permalink) Old 03-11-2019, 08:05 PM
dan woodland's Avatar
Quoted: 34 Post(s)
As you know they are operated by vacuum in both directions... sounds like some vacuum lines are crossed?
*67K miles... Under Construction* :)
dan woodland is offline
post #3 of 7 (permalink) Old 03-11-2019, 09:58 PM Thread Starter
Big Dave's Avatar
Even though when the engine is running they work perfectly? The headlight doors only come down when the engine is off. There is only one vacuum line from the manifold that T's off to the switch and vacuum canister.
Big Dave is offline
post #4 of 7 (permalink) Old 03-11-2019, 10:00 PM
BLK69JUDGE's Avatar
Quoted: 74 Post(s)
Hello Big Dave
I tinker with hideaways as I have had several sets and own 3 now
give me a ringaroooo it easier than typin'
several things come to mind right off
Scott
pm sent
BLK69JUDGE is online now
post #5 of 7 (permalink) Old 03-13-2019, 07:15 PM
dcoydad's Avatar
Quoted: 6 Post(s)
I just adjusted mine. I disconnect the vacumn lines and adjust the alignment and springs so the lights stay closed at rest. The spring tension holds them down from the back side at rest. If you force them open the springs relax and then apply pressure again at open. The actuators only work during the open/close call from switch to overcome the springs. I had to bend my spring stems slightly to offset the loss of tension from their age. Once adjusted to stay closed at rest, re-hook your lines. Even if the vacumn leaks off the springs should hold the lights closed.
dcoydad is offline
post #6 of 7 (permalink) Old 03-13-2019, 09:26 PM
BLK69JUDGE's Avatar
Quoted: 74 Post(s)
very well spoken.....dcoydad
and by the way ? my neck hurts looking at your avatar ....
Scott
post #7 of 7 (permalink) Old 03-14-2019, 10:51 AM
dcoydad's Avatar
Quoted: 6 Post(s)
Me too. I can fix my headlights but can't seem to get my pics to post right side up!!!
dcoydad is offline
1968 GTO Hideaway Doors 68GTO_MAN 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 5 05-06-2017 05:30 PM
1968 complete doors frankrp 1964-1974 GTO parts for sale (Price & Pictures Required) 0 10-26-2016 08:59 PM
Tip for adjusting saggy hideaway headlight doors Heatwave 1964-1974 Tempest, Lemans & GTO General Discussion 0 10-02-2016 12:16 PM
Hideaway Headlight Doors Only? Perry 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 2 10-10-2014 08:44 PM
