1968 Lemans, shift console removal? - Pontiac GTO Forum
post #1 of 7 (permalink) Old 01-16-2012, 06:03 PM Thread Starter
Front and back are loose. The center is not moving. I'm looking to confirm that there are screws somewere under the indicator plate. If so does the plate just lift straight up? I thought I'd ask before I start prying up and break something. There are no visible screws showing to remove the plate. Thanks
supercab78 is offline
post #2 of 7 (permalink) Old 01-16-2012, 06:09 PM
Quoted: 23 Post(s)
If i remember from my 69' firebird you need to take off knob (C-clip) remove indicator trim plate, remove indicator, two screws front of trans hump to a bracket underneath and screw each side towards the back and one holding console to shifter housing from top.....been 30 years so i may be a bit foggy on it...
Instg8ter is offline
post #3 of 7 (permalink) Old 01-17-2012, 08:34 AM
I know 69's have a different shifter than the 68's, but mybe this will help. To get mine out, in addition to removing all the console mounting screws, I have to remove the console box insert and then go in through the opening to remove two bolts that mount the shifter to a bracket that's bolted to the floor pan. That lets me lift up the console and shifter together enough to be able to disconnect the cable from the shifter, and then remove the console and shifter as a unit. The trim bezel around the shift lever on my 69 -was- held in by a couple of press-on speed nuts. I say -was- because the first time I removed it, I didn't know how it all went together so I pried up on the bezel to try to remove it and broke off both the mounting studs (doh!) - but it fits tightly enough into the recess around the shifter to keep it in place without them (whew!).
My 69 console fastens to the floor in 4 places: two sheet metal screws "inside" through a bracket at the rear, one sheet metal screw at the front center through the 'nose' of the console, and one large sheet metal screw/bolt through a bracket that's just behind the shifter.
BearGFR is online now
post #4 of 7 (permalink) Old 01-17-2012, 09:30 AM Thread Starter
BearGRR; Sounds like the 68 might be the same way. I forgot to state that it is an automatic trans. Don't know if that makes a difference. We will be working on it later today. I'll let you know if you are correct. Thanks
post #5 of 7 (permalink) Old 01-17-2012, 02:51 PM
FlambeauHO's Avatar
Quoted: 8 Post(s)
Don't know if yours is like the Hurst his and hers but it mounts to the floor with two screws in the back and mounts to the console with two in the front. To get there remove chrome shift gate and indicator + lens. Console of course comes out before you can get to aft screws. Good luck
FlambeauHO is offline
post #6 of 7 (permalink) Old 01-17-2012, 03:56 PM Thread Starter
It's off! It came of the way BearGFR's did on his car. Thanks for the post everyone it saved us time and no broken parts trying to figure it out.
post #7 of 7 (permalink) Old 01-18-2012, 07:44 AM
Airbag install/console removal SleeperGoat Interior Discussions 4 10-28-2011 09:05 AM
1968 Lemans front bumper removal sknight751 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 1 06-28-2010 07:36 AM
shift boot removal? hurleymotoxer118 Interior Discussions 0 06-01-2007 06:46 PM
Shift knob removal? GoatBoy4056 2004-2006 GTO General Discussion 1 12-26-2006 05:02 PM
