1968 rear deck filler and package tray repair - Pontiac GTO Forum
post #1 of 6 (permalink) Old 02-16-2015, 10:43 PM Thread Starter
Recenty replaced my rusty rear filler (behind glass in front of trunk lid) and got a better look at the rear portion of the package tray support that runs back to the trunk gutter.This was also junk and needed to be replaced but is not available so I cut out the old one ,purchaced two fillers trimmed off the gutter on one flipped it upside down welded it in where the support was then welded in the other in it's spot so now it is solid and undetectable .
frankrp is offline
post #2 of 6 (permalink) Old 02-17-2015, 06:10 AM
Frank, got any pictures of this surgery? Sounds like it went very well. Matt
Matthew is offline
post #3 of 6 (permalink) Old 03-02-2015, 08:51 PM Thread Starter
reply to reply
No but I probably should have
frankrp is offline
post #4 of 6 (permalink) Old 04-30-2015, 06:20 PM
apl
68 Package Tray
You also could have used a readily available repro package tray for a 68 Chevelle. I had the same rust issues. Figured I could do the reverse filler panel trick or have a package tray fabricated because mine was gone from the glass seat to the trunk lid track and i could only find one used from a gto parts guy, oh, and the sweetheart wanted $800. I took the chance with a $150 Chevy 68 A body Chevelle tray figuring some modification would be necessary. To our surprise it went in as a direct replacement with no modification required. Fits and looks original inside and out. I let the folks I ordered it from know for the next guy with this problem.
apl is offline
post #5 of 6 (permalink) Old 03-13-2018, 09:51 PM
Thank you, Thank you, Thank you!!!
Yes, finally the post I was looking for! Every bit of me told me that those trunk filler panel undersides would be the same. They look exactly the same! I was trying to get this info from a man at Goodmark and he couldn't be bothered to even look into this possibility of the crossover. All he said is that there aren't enough GTOs to tool up for that piece. I said if you find out that it works then you could offer them to Pontiac guys, He then replied... I don't have time for that kinda stuff. What a dumb ass!
Lawrence Pollman is offline
post #6 of 6 (permalink) Old 03-14-2018, 10:49 AM
1968gto421's Avatar
Quoted: 72 Post(s)
Good news, where did you buy your '68 Chevelle tray, sounds like the answer (and nuts to Goodmark).
1968gto421 is offline
65 Gto rear deck filler question ElMedioGringo 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 0 08-13-2012 02:53 PM
66 rear deck filler question Logchain 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 1 12-25-2011 04:31 PM
rear deck filler panel tspring 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 2 09-23-2011 07:46 AM
New rear package tray install advice needed gotyorgoat 1964-1974 Tempest, Lemans & GTO General Discussion 1 09-13-2011 05:09 PM
69 Lemans package tray repair Jays69 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 03-02-2009 01:13 PM
