1969 GTO Body Alignment - Floor Replacement - Pontiac GTO Forum
post #1 of 6 (permalink) Old 10-07-2012, 08:48 AM Thread Starter
I have a 1969 GTO that I'm in the process of replacing the entire floor. I have the car body hanging from my garage ceiling using chain hoists. I welded braces across the top and bottom of each door opening, and then 2 diagonal braces. I cut the rocker panels off, and nothing seemed to move.
Yesterday, while I was working on removing floor remnants, I jacked the back of the car higher in the air. At one point, I noticed that the body looked very twisted. Sure enough, the front cowl to rear body section alignment is now completely off. Something moved or flexed and I can't see what it is. I guess I did not brace it adequately.
Where do I go from here? Do I need to purchase or build some kind of body alignment table or jig? Is there a manual that has body dimension specs in it that a shop would use? My car body is effectively two separate pieces now, and I need to be able to weld a new floor and rocker panel section in and know that everything is in alignment.
Thanks!
451stroker is offline
post #2 of 6 (permalink) Old 10-07-2012, 12:27 PM
Got photos?
BearGFR is online now
post #3 of 6 (permalink) Old 10-07-2012, 10:12 PM
I would suggest you purchase new body bushings and place the body back on the frame. Leave the body attached to the frame while replacing sheet metal.
05GTO is online now
post #4 of 6 (permalink) Old 10-08-2012, 07:37 AM Thread Starter
I'll try to get some photos up today. The reason I had the car off the frame is because I had completely cut out what remained of the original floor, including the body to frame mounts. With the new floor in place on the frame, hopefully I'll be able to massage everything back into place.
I'm sure there has to be some kind of body or chassis manual that provides measuring points and dimensions. A manual like a collision shop would use when straightening a car on a frame machine.
post #5 of 6 (permalink) Old 10-10-2012, 05:23 PM
The dimensions you need should be in the Resto Manual (P. Zazzarine)....What Randy said makes perfect sense....place the body on the frame you are using....layout the floors and tack them in place. Go from there.....Eric
Eric Animal is offline
post #6 of 6 (permalink) Old 10-10-2012, 09:34 PM
After you tack weld the body braces in place the body should be more stable, for the best results I would suggest plug welding all of the body braces, floor and trunk pans. The floor and trunk pan overlapping can be hidden by using a seam sealer, all metal or metal-2-metal filler. To get the best and strongest results use a flanging tool with a hole punch.
05GTO is online now
LH trunk floor replacement Logchain 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 4 01-10-2012 01:58 PM
1969 GTO Fuel Tank Replacement CPK1969 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 10 09-11-2011 02:15 AM
Replacement floor pans input sr71 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 08-14-2010 01:09 AM
Floor Pan Reproduction Replacement Panels? JRB67 1964-1974 Tempest, Lemans & GTO General Discussion 3 07-31-2010 09:23 AM
Heater core replacement 1969 gto silky58 1964-1974 Tempest, Lemans & GTO General Discussion 3 07-30-2009 04:29 PM
