1969 GTO Conv 4 spd -Saved from the woods - Pontiac GTO Forum
 7Likes
post #1 of 18 (permalink) Old 11-07-2016, 01:05 PM Thread Starter
derbydiva's Avatar
Quoted: 5 Post(s)
This car had basically been abandoned by the owner, out in the woods for the last year with hols n the top and LH window broken out... Took some persuasion (and $$$$) but he finally let it go. Spent more than I wanted to, but it's was still a fair deal. Sad thing is, it's a 2nd owner car with only 41k on it, and was really nice just 10 years ago....
So trying to figure out what this engine is, found a stamped number SR 8 48 30, in front on RH side of engine (LH side if you're looking at it from the front). Assuming it's a service replacement block, would that # be the consect. # from another car?
See another #, raised, 6M-5, may have a D below it. Another raised # looks like L168. Can anyone make sense of these? Can't access any #'s on the distrib pad, and no raised casting #'s on front.
What a mess in the engine compartment..... See next post for engine # pics.
Appreciate any observations/info!
Darcie
ID:	82697   Click image for larger version
ID:	82705   Click image for larger version
ID:	82713   Click image for larger version
ID:	82721   Click image for larger version
derbydiva is offline
post #2 of 18 (permalink) Old 11-07-2016, 01:25 PM Thread Starter
derbydiva's Avatar
Quoted: 5 Post(s)
Pic of engine #'s
ID:	82737   Click image for larger version
ID:	82745   Click image for larger version
post #3 of 18 (permalink) Old 11-07-2016, 08:37 PM
Quoted: 349 Post(s)
Agree that the "SR" most likely is Service Replacement. The heads appear to be 1968 #16 heads dated L=December, 16 = day of month, 8 = year, 1968. So the heads are late production 1968 heads. New model year, 1969, would begin in September 1968 so it is not uncommon to have 1968 castings going into an early production car - which yours may be.
The codes at the distributor will provide more info on the block. Casting number for 1968 & 1969 is 9790071 (Ram Air is 9792506). Just under the casting number near the edge of the block is the date code.
You also want to get the PHS documents for your car which will tell you when it was built and its options. If it is an early production 1969 GTO, then I would say the heads are original to the car and you need to confirm the date on the block, which may give you an idea when the block was replaced.
derbydiva likes this.
post #4 of 18 (permalink) Old 11-07-2016, 09:03 PM Thread Starter
derbydiva's Avatar
Quoted: 5 Post(s)
Thx Jim, is it possible to access these numbers with the engine installed? I can't figure out how you could...maybe the config he's got going on with the coil so close to the distrib isn't factory? I need to get a good pic of how the engine should look (I've been more of a Ford girl and this is completely different), so I can get it back to original- I know he removed the PS and then moved the alt...was in the process of moving the battery to the trunk. Yikes.
Darcie
post #5 of 18 (permalink) Old 11-08-2016, 07:08 AM
Picture shows a L168 dated,#48 casting head, not a '68 model #16 . Big valve #16 's being factory installed on '69 model V8's is disinformation that made it into the most common copied code book, that happened nearly 30 years ago. Have owned several early '69 model WT's, all had original date matching #48 's. Same experience with hundreds of other long time Pontiac collectors. '69 YS coded 400 blocks eceived #62 casting heads.
On this convert, body tag shows an 11C body tag build. Not sure if Baltimore plant had a body bank. Even if Baltimore had a body bank, looking at a time window of a painted body having to set in the body bank 6 weeks, minimum, so it could be united with an original engine with L168 dated heads. With no UAW strike, to throw things off, would surmise the 4 week later cast #48 heads are not original, but were picked up & installed at a later date on the SR fitted short block.
The block casting number is cast on the block flange area coming up from the oil filter hsg mtg pad. A fully ground off & stamped "071' 400 block casting have never ran across. Have had in my hands, many original "2506"s both original use, and SR's. Once the #48 1988 casting 400 blocks began being cast in June of 1970, SR 4 bolt 400 blocks had all 6 digits ground off & was replaced by the applicable 400 4 bolt casting number. Similar deal with 428's. On the block in the above '69 convert, it would be of interest to know the alphanumeric casting date by the distribution hole.
Congrats on the save! Being in MN, you are in a hotbed of GTO restorer/enthusiasts! Need select condition hard to find original parts, GTO JOHN used to post on this board. He as well as a good friend further west, both are deep stocked on '69 parts & '69 projects. Need their numbers, can fwd them.
Last edited by Pinion head; 11-08-2016 at 08:07 AM. Reason: Tried to post this while waiting in line to VOTE!
post #6 of 18 (permalink) Old 11-08-2016, 03:50 PM Thread Starter
derbydiva's Avatar
Quoted: 5 Post(s)
While I try to figure out what all that means lol, I would love some contact info for parts- got a lot of orig stuff missing in the engine compartment for sure. Feel free to message me here, or email me at [email protected]
Thx for the info!!
Darcie
post #7 of 18 (permalink) Old 11-08-2016, 06:08 PM
Quoted: 349 Post(s)
PH is 100% correct on the heads, my bad. A quick look and I saw #16 on the center port. So that indeed changes things a bit. The 2-digit casting number on the exhaust center port is what we are referring to in ID'ing the heads. Here is a link that gives you a little more info on those heads. Here is what to look for in ID'ing: http://www.wallaceracing.com/5chead.jpg First letter in month goes "A"=January, "B"=February, "C"=March, etc., then 2-digit is day of the month, last digit is the year.
OK, using the book Pontiac Musclecar Performance 1955-1979 by Pete McCarthy, the #48 heads were used on the HO (High Output) 350CI/330HP, 400CI/350HP, 400CI/366HP Ram Air III engines. Definitely a good head to have/use on any Pontiac performance engine, but with stock pistons, the compression will be too high to enjoy pump gas and you will need a good high octane racing gas to run it without detonation.
Again, the Pontiac Historical Services (PHS) will have the build sheet for your car and worth getting in helping you ID exactly what engine/trans/rear your car originally came with from the factory. Maybe it came from the factory with a Ram Air III engine which would add a big value to the car.
Check out the Wallace website as it has a lot of good info and all kinds of "Automotive Calculators" which can be very helpful when building an engine. Wallace Racing-Drag Racing Pontiac powered Firebirds,Trans Ams and Dragsters
Do you know that the engine is a 400CI and not a 350CI? Here is a good site which shows you where to look: How to identify your Pontiac engine
post #8 of 18 (permalink) Old 11-09-2016, 09:50 AM Thread Starter
derbydiva's Avatar
Quoted: 5 Post(s)
I do not. I spoke to the guy I bought it from, and he said he rebuilt the engine it came with, he assumed it was orignal. His dad bought it in 1988 and they could tell it had not been touched in many years at that time, so guessing the swap would had to have been done a long time ago. He is looking for the PHS docs that his dad ordered many years ago, I'll give that a few more days and then I'll reorder it.
What's interesting to me is, the '69 GTO 400/4 spd convert I owned in the early 80's (I actually posted here looking for it a couple years ago), also had a service block, orig owner told me it blew up right before the factory warranty expired and he got a brand new one. Kinds odd that so many seem to have had this happen.
Wish I could access the back of the block. Thx for the info, it's much appreciated!
Darcie
post #9 of 18 (permalink) Old 11-09-2016, 03:45 PM Thread Starter
derbydiva's Avatar
Quoted: 5 Post(s)
OK my son and I were determined to get these #'s, so he crawled into the engine compartment- here's what we got:
9790071
Correct casting # for a 68/69 400 engine?
D140
Apr 14 1970?
70
1970?
GM-5 D N
And again the engine code is SR 8 48 30.
Service block, and who knows what that # is for...
So to me, it looks like Pontiac replaced the engine in 1970, with the correct one. Am I right?
Still working on getting the PHS docs to see if the 400 was a HO.
Thanks for all the help!
Darcie
Name:	GTO 400 stamping.jpg
ID:	82818   Click image for larger version
Name:	GTO engine #.jpg
ID:	82826   Click image for larger version
Name:	GTO engine casting #.jpg
ID:	82834   Click image for larger version
Name:	GTO Engine Date code.jpg
post #10 of 18 (permalink) Old 11-09-2016, 08:23 PM
Quoted: 349 Post(s)
OK, its a 400CI, easily ID'd by the "400" casting which indicates the cubic inch, so not a 350CI.
The D/N refers to what shift the block was cast, D=Day, N=Night and the arrow points to the "D".
You are correct on your dates of the block and you will also see "70" above that which further indicates a "1970" block.
The casting number for the 1970 block is different from the 1969 block. The 1970 block is cast 9799914, but you can see that the last four digits have been ground off and 0071 stamped in their place. This would reflect the engine casting for 1969 to which your original engine would have come with. So, being no expert, the original engine went bad under warranty and a Service Replacement engine (either block or short block assembly) was installed with the casting code restamped (possibly by the dealer who did the warranty work) to reflect the casting numbers of the original engine block. So I don't think there is any "trickery" going on here, just simply a warranty replacement block was put in the car.
As for the heads, Pontiac did things that are not always textbook correct and the internet/books are not always 100% either. Most say the #48 heads are the RA III heads, some say they were used on the GTO engine due to which factory they were assembled at. What does seem to be in agreement is that the #48 heads were used on the manual transmissions GTO's which yours is. So I would be inclined to believe that the heads are original to the car and were re-used on top of the Service Replacement block - which would make sense.
Once you get the PHS documents, you will be able to verify the original engine code and know what HP engine your car would have been built with. So you still have a unique piece of history in that you have a car with a Service Replacement block original to the car under warranty work done at the Pontiac dealership. How many GTO's can claim that?
Can this bumper be saved? BatmanGTO 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 16 08-01-2011 10:30 PM
Newbie 1969 GTO Conv 53 Blue Flame 1964-1974 Tempest, Lemans & GTO General Discussion 25 01-07-2009 08:43 AM
Bring out your GOAT to Bussie Woods tabes117 Great Lakes 0 03-09-2007 11:01 AM
05 GTO Race Of The Century!!! GTO Saved My Life! Nightshifter Racing and Kill Forum 16 07-12-2005 06:13 PM
